[GRASS-user] r.update
Dave Roberts dvrbts at ecology.msu.montana.edu
Wed Jan 1 12:10:14 PST 2014
Friends,
     After some alternative approaches to a simple problem of
compositing rasters (see previous posts, esp. compositing rasters @9:32)
I developed a very crude function to update rasters
r.update target mask x y
updates raster target by substituting y everywhere that raster mask has
x.  A more GRASS-like syntax would be
r.update target=string mask=string current=integer replace=integer
but my bash skills are pretty limited and I elected (for the time being)
not to parse the arguments that way.  The current function relies on a
short bash script and a FORTRAN executable.  The crude part is exporting
both the target an mask rasters as ascii exports, creating a new ascii
file, and doing an r.in.ascii to bring the updated raster back in.  It
only works (at present) for integer rasters, but it's intended for
thematic maps, so that seems OK.
r.update.sh just below.
r.out.ascii inp=$1 out=$1.asc null=-1
r.out.ascii inp=$2 out=$2.asc null=-1
g.remove rast=$1
r_update $1.asc $2.asc $3 $4
r.in.ascii  inp=tmp.file out=$1 nv=-1
rm $1.asc
rm $2.asc
rm tmp.file
You have to "alias r_update 'sh r_update.sh'" or name the script
r.update and chmod +x r.update to make it run as shown.
The FORTRAN code for r_update is at
ecology.msu.montana.edu/GRASS/r_update.f90
The code compiles with gfortran.  The executable must be in your path,
or you can modify the bash script with a full path to it.
     It is my sincere hope that someone with GRASS chops will write a
function for g.extension that uses the API and avoids all this ascii
input and output, but this serves as a demo and useful (if clumsy)
approach in the meantime.
Dave
David W. Roberts                                     office 406-994-4548
Professor and Head                                      FAX 406-994-3190
Department of Ecology                         email droberts at montana.edu
Montana State University
Bozeman, MT 59717-3460
