[GRASS-user] r.update
Dave Roberts
dvrbts at ecology.msu.montana.edu
Wed Jan 1 14:11:05 PST 2014
Hi Anna,
On 01/01/2014 01:50 PM, Anna Petrášová wrote:
> Hi Dave,
>> On Wed, Jan 1, 2014 at 3:10 PM, Dave Roberts
>> <dvrbts at ecology.msu.montana.edu <mailto:dvrbts at ecology.msu.montana.edu>>
>> wrote:
>> Friends,
>> After some alternative approaches to a simple problem of
>> compositing rasters (see previous posts, esp. compositing rasters @9:32)
>> I developed a very crude function to update rasters
>> r.update target mask x y
>> updates raster target by substituting y everywhere that raster mask
>> has x. A more GRASS-like syntax would be
>> r.update target=string mask=string current=integer replace=integer
> I'm not sure if I don't miss anything but why don't you use r.mapcalc
> expression like this:
> new = if(mask == x, y, target)
> and then
> g.rename new,target --overwrite
well probably because I'm not too bright. Obviously your elegant
solution would allow multiple sequential updates just the way I needed
as long as I do the rename --overwrite very time. I knew there had to e
GRASS way to do this, I just hadn't figured it out yet.
Thanks!
> Anna
> but my bash skills are pretty limited and I elected (for the time
> being) not to parse the arguments that way. The current function
> relies on a short bash script and a FORTRAN executable. The crude
> part is exporting both the target an mask rasters as ascii exports,
> creating a new ascii file, and doing an r.in.ascii to bring the
> updated raster back in. It only works (at present) for integer
> rasters, but it's intended for thematic maps, so that seems OK.
> r.update.sh <http://r.update.sh> just below.
> r.out.ascii inp=$1 out=$1.asc null=-1
> r.out.ascii inp=$2 out=$2.asc null=-1
> g.remove rast=$1
> r_update $1.asc $2.asc $3 $4
> r.in.ascii inp=tmp.file out=$1 nv=-1
> rm $1.asc
> rm $2.asc
> rm tmp.file
> You have to "alias r_update 'sh r_update.sh'" or name the script
> r.update and chmod +x r.update to make it run as shown.
> The FORTRAN code for r_update is at
> ecology.msu.montana.edu/GRASS/__r_update.f90
> <http://ecology.msu.montana.edu/GRASS/r_update.f90>
> The code compiles with gfortran. The executable must be in your
> path, or you can modify the bash script with a full path to it.
> It is my sincere hope that someone with GRASS chops will write
> a function for g.extension that uses the API and avoids all this
> ascii input and output, but this serves as a demo and useful (if
> clumsy) approach in the meantime.
> Dave
> ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~__~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~__~~~~~~~~~~~~
> David W. Roberts office
> 406-994-4548 <tel:406-994-4548>
> Professor and Head FAX
> 406-994-3190 <tel:406-994-3190>
> Department of Ecology email
> droberts at montana.edu <mailto:droberts at montana.edu>
> Montana State University
> Bozeman, MT 59717-3460
> _________________________________________________
> grass-user mailing list
> grass-user at lists.osgeo.org <mailto:grass-user at lists.osgeo.org>
> http://lists.osgeo.org/__mailman/listinfo/grass-user
> <http://lists.osgeo.org/mailman/listinfo/grass-user>
David W. Roberts office 406-994-4548
Professor and Head FAX 406-994-3190
Department of Ecology email droberts at montana.edu
