[GRASS-user] Using r.stream.basins for several outlet points
Markus Neteler
neteler at osgeo.org
Thu Jan 2 14:09:09 PST 2014
On Fri, Dec 27, 2013 at 10:47 AM, Micha Silver <micha at arava.co.il> wrote:
> I'm reading the wiki [1] on the r.stream.basins module, and a question has
> come to mind.
> I want to create the drainage areas for many specific pour points. The
> sample in the wiki page, using r.reclass on the streams raster, reads:
> echo '42 = 42
> 252 = 252
> 188 = 188
> * = NULL' >tmp
> r.reclass input=streams output=sel_streams_1 <tmp1
> r.stream.basins dir=dirs stream=streams basins=bas_basin_3
> Should the last line not be:
> r.stream.basins dir=dirs stream=sel_streams_1 basins=bas_basins_3
> Also, for clarity, perhaps "tmp" should be "tmp3" in both cases above
I have attempted to fix that, please review
http://grasswiki.osgeo.org/grass-wiki/index.php?title=R.stream.*&diff=20069&oldid=17583
For further corrections you may update directly the Wiki since it is a Wiki :-)
Best
Markus
