[GRASS-user] r.sunmask cast shadow question
Markus Neteler
neteler at osgeo.org
Sat Jan 4 10:04:59 PST 2014
On Sat, Jan 4, 2014 at 12:17 PM, Tim Michelsen
<timmichelsen at gmx-topmail.de> wrote:
> Perhaps r.sun.hourly should get
> * average sunlight duration per day during a month, etc. (h/d)
This needs some modifications in the r.sun code. I was discussing this
issue some time ago with Jaro Hofierka who gave the following hints:
On Thu, Apr 16, 2009 at 18:34, Jaro Hofierka <hofierka at geomodel.sk> wrote:
> Markus,
> sunrise, sunset times are calculated for each cell, however, not including
> shadows by surrounding terrain features. This would need another test which
> in fact is done during radiation calculations (there is a time step to sum
> up radiation), but the time is not stored.
> To minimize a number of output maps we have stored the information of
> sunrise/sunset times using min-max values in a history file (or a single
> value when a single value of latitude is used for the map). So it would need
> a modification of the code to put there extra files storing sunrise-sunset
> times. If you need a quicker solution, you would need to make tests just for
> a small part of the day (e.g. 1-2 hours around reported sunrise/sunset
> times).
> Jaro
Perhaps useful as a pointer.
Markus
