[GRASS-user] WCS import into GRASS GIS - select region extent only
Markus Neteler
neteler at osgeo.org
Sat Jan 4 14:14:14 PST 2014
Hi Stefan,
On Sat, Jan 4, 2014 at 10:40 PM, Blumentrath, Stefan
<Stefan.Blumentrath at nina.no> wrote:
> Hi Markus,
> I should not write emails offline ;-), so sorry for reposting parts of your answer...
> And thanks for the hints. I was not aware that the BBOX had no effect in the XML.
... this is what I understood from FrankW's email.
> Hopefully, the HEIGHT and WIDTH parameter work, as Martin seemed to have problems to fetch the data for his region due to tile-size limits...
Please add your findings in this new Wiki page:
http://grasswiki.osgeo.org/wiki/WCS
> If you consider enhancing r.external (or r.in.gdal) in the direction of a projwin option, maybe a "limit import to current region flag" would be more easy to use and maybe also more consistent (like e.g in v.in.ogr).
Indeed, this is a long-term wish for me :-)
The code in
http://svn.osgeo.org/gdal/trunk/gdal/apps/gdal_translate.cpp
should give some inspiration...
Best
Markus
