[GRASS-user] WCS import into GRASS GIS - select region extent only
Markus Neteler
neteler at osgeo.org
Sun Jan 5 02:29:28 PST 2014
On 1/4/14, Blumentrath, Stefan <Stefan.Blumentrath at nina.no> wrote:
> Actually, a second vrt does the trick:
> gdalbuild vrt dem_wcs_bb.vrt dem_wcs.vrt -te 381464.564874 7282848.63791
> 422460.634623 7310018.58218
> This worked for me.
> I shall add the solution to the Wiki.
This is probably better than a -r flag for the raster import. The
issue is that if the resolution of the current region does not match
that of the raster map or layer to be imported, resampling is needed.
But which? It depends on the input data (for available methods in
GRASS, see the 'Interpolation' page in the Wiki).
Hence, reflecting about it again, such a convenient flag is not easily
integrated...
Markus
