[GRASS-user] WCS import into GRASS GIS - select region extent only
Blumentrath, Stefan
Stefan.Blumentrath at nina.no
Sun Jan 5 13:48:11 PST 2014
Hi Martin and Markus,
The GDAL VRT-format is really very handy for many kinds of data extraction, so I simply applied one of my most important learning-strategies (not only for GIS): "try-and-error"
However, I have to admit, that I did not really understand your last question, Martin:
What do you mean by a "bunch of vrt" if you only have 4 maps? Did you set -te according to the size limits of the server and therefor get maybe hundrets of tiles? And if r.in.gdal allows you to import more than WCS-limits for HEIGHT and WIDTH, did you try to import your entire region of interest through the second vrt?
Alternatively you could try something like this (Unix shell script for GRASS 6.4 (in GRASS 7 r.tileset seems to be still broken, see http://trac.osgeo.org/grass/ticket/1825):
This solution assumes that you set your GRASS region to your entire area of interest...
source_prj=`eval g.proj -fj`
r.tileset sourceproj="$source_prj" maxcols=1024 maxrows=1024 fs=' ' --q | awk '{print "gdalbuildvrt ./dem_wcs_bb_"NR".vrt ./dem_wcs.vrt -te " $1, $2, $3, $4 }' | sh
gdalbuildvrt vrtmosaic.vrt dem_wcs_bb_*.vrt
r.in.gdal input=vrtmosaic.vrt output=test_wcs
Please note that the WCS I used for testing probably does not have any tile-limits because I am having no issues (on UBUNTU 12.04 and GRASS 7 / GRASS 6.4.4).
As for the r-flag Markus mentioned: personally I would not miss it in r.external because data is not really duplicated, or are there drawbacks when registering big external datasets?
In r.in.gdal it might be useful, but does the module change the resolution or would it do so if a bounding box is applied to the input-raster?
Cheers
Stefan
-----Original Message-----
From: martin.zbinden at gmail.com [mailto:martin.zbinden at gmail.com] On Behalf Of Martin Zbinden
Sent: 5. januar 2014 00:10
To: Blumentrath, Stefan
Subject: Re: [GRASS-user] WCS import into GRASS GIS - select region extent only
Wow, great! This trick with a second VRT works with gdal_translate and r.in.gdal, with the second even in case of regions bigger than MAXSIZE. How did you find that out, if I may ask you?
What do you think: I have to handle at least 4 raster maps. What is the most efficient way to organize this bunch of VRTs?
I think, I could base on the function _createXML() from r.in.wms2 an generate the VRT myself. The second VRT introduces the following important lines depending on TE parameter:
<VRTDataset rasterXSize="2750" rasterYSize="1750"> <GeoTransform> 2.5920000000000000e+06, 2.0000000000000000e+00, 0.0000000000000000e+00, 1.1825000000000000e+06, 0.0000000000000000e+00, -2.0000000000000000e+00</GeoTransform>
<SrcRect xOff="53296" yOff="56718" xSize="174216" ySize="110331" />
Cheers and good night
Martin
Martin Zbinden
Riedacker 523
3154 Rüschegg Heubach
+41 78 628 28 82
2014/1/4 Blumentrath, Stefan <Stefan.Blumentrath at nina.no>:
> Actually, a second vrt does the trick:
> gdalbuild vrt dem_wcs_bb.vrt dem_wcs.vrt -te 381464.564874
> 7282848.63791 422460.634623 7310018.58218
> This worked for me.
> I shall add the solution to the Wiki.
> Cheers
> Stefan
> Sent: 4. januar 2014 23:32
> To: Blumentrath, Stefan; neteler at osgeo.org
> Cc: grass-user at lists.osgeo.org
> extent only
> Hi Stefan, hi Markus,
> I just started to think over everything again after Stefans first maill... thanks for the fast reaction. I just tried the proposed HEIGHT and WIDTH parameter with gdal_translate without success.
> I started to observe the HTTP-transfer with mitmproxy [1]. I can see, that BBOX parameter is just ignored. Also i can see, that r.in.gdal by itself seems to know about tile-size-limitations and starts to download small 2MB-tiles, while gdal_translate just tries to get it all in one file. If you are interested in more details, I can share these observations on the new WCS-wikipage?
> Concerning the "limit import to current region flag" I agree absolutely with you two, I would just take it with a handkiss. Would this -r flag be something easy and quick to implement? I see that r.in.gdal is a compiled binary, so nothing I believe I can do myself.
> Thanks to for the python-based-approach, which hopefully will respect tile-size limits. I'll give it a try, until the -r flag will be reality.
> Cheers,
> Martin
> [1] http://mitmproxy.org/
