[GRASS-user] running r.sun with ancillary layers.
Giuseppe Amatulli
giuseppe.amatulli at gmail.com
Tue Jan 7 10:59:36 PST 2014
I need some suggestions to run r.sun and use the
Albedo-Modis<http://modis-atmos.gsfc.nasa.gov/ALBEDO/index.html>product
as an input for the r.sun albedo parameter.
Albedo-Modis <http://modis-atmos.gsfc.nasa.gov/ALBEDO/index.html> has two
main products: *White-sky and ** Black-sky*
*White-sky is the bihemispherical reflectance under conditions of isotropic
illumination, so it has the angular dependency removed. Black-sky is the
directional hemispherical reflectance computed at local solar noon."*
Which one of these is the most appropriate to use?
Moreover, "white-sky" and "black-sky" are computed at 10 wavelengths
(0.47µm, 0.55µm, 0.67µm, 0.86µm, 1.24µm, 2.1µm, 0.3-0.7µm, 0.3-5.0µm, and
0.7-5.0µm).
Which one is the most appropriate to use?
The only info that i found for this is
*i.albedo calculates the Albedo, that is the Shortwave surface reflectance
in the range of 0.3-3 micro-meters. It takes input of individual bands of
surface reflectance from Modis, AVHRR, Landsat or Aster and calculates the
Albedo for those. This is an precursor to r.sun and any Energy-Balance
processing. *
so the 0.3-5.0µm should be the more suitable for this purpose. Correct?
My final aim is to use ancillary layers to "fill" all the different
parameters of r.sun.
All the examples that i found use constant or default values.
May anyone point to me some source of information?
Thanks in Advance
Giuseppe Amatulli, Ph.D.
Center for Earth Observation
ESC Room 119A
Yale University
P.O. Box 208109
New Haven, CT, 06520-8109
Teaching: spatial-ecology.net
Work: <http://www.exeter.ac.uk/esi/people/casalegno/>
http://sbsc.yale.edu/training-and-support
<http://www.spatial-ecology.net>
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20140107/e40726e2/attachment.html>
