[GRASS-user] Python error with GRASS 7 on Windows 8
Nuno Sá
nunocesardesa at gmail.com
Wed Jan 8 09:11:54 PST 2014
(Wed Jan 08 17:10:18 2014)
g.extension.py extension=i.landsat.dehaze operation=add
WARNING: GRASS_ADDON_PATH has more items, using first defined -
'C:\Users\Invader\AppData\Roaming\GRASS6\addons'
WARNING: Extension <i.landsat.dehaze> already installed. Re-installing...
Downloading precompiled GRASS Addons <i.landsat.dehaze>...
Updating metadata file...
Installation of <i.landsat.dehaze> successfully finished
(Wed Jan 08 17:10:22 2014) Command finished (4 sec)
indeed, that was the error :P
But.... the dehaze continues to not work :'( same error as before
On 8 January 2014 16:47, Martin Landa <landa.martin at gmail.com> wrote:
> Hi,
> 2014/1/8 Nuno Sá <nunocesardesa at gmail.com>:
> > (Wed Jan 08 13:05:25 2014)
> > g.extension extension=i.landsat.dehaze operation=add
> > which: svn: unknown command
> > ERROR: svn client required. Please install Subversion first.
> > (Wed Jan 08 13:05:26 2014) Command finished (0 sec)
> g.extension in G6 is a shell script which does not work on Windows.
> The wxGUI wrapper is using python script which is taken from G7.
> Unfortunately wxGUI wrapper for installing extensions doesn't work
> (known problem [1]). In other words, Windows users have only one
> possibility to install an extension from wxGUI command line by running
> g.extension.py ext=<extension>
> Note '.py' extension! Martin
> [1] http://lists.osgeo.org/pipermail/grass-dev/2014-January/066801.html
Nuno César de Sá
+351 91 961 90 37
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20140108/96f18a05/attachment.html>
