[GRASS-user] grass-python editing using Wing-IDE
Milton Ribeiro
miltinho.astronauta at gmail.com
Sat Jan 18 17:22:44 PST 2014
Hi Vaclav,
Yes, the idea is just for script editing, but to run the script I will do
within grass GUI.
I will also setup PYTHONPATH as you suggested
cheers
milton
2014/1/18 Vaclav Petras <wenzeslaus at gmail.com>
> On Sat, Jan 18, 2014 at 6:47 PM, Milton Ribeiro <
> miltinho.astronauta at gmail.com> wrote:
>> Hi there
>> Just to keep the info, I found it, and now everything is working fine
>> with autocomplete under Wingware.
>> I copied the folder "C:\Program Files (x86)\GRASS GIS
>> 6.4.3RC2\etc\python\grass" to
>> "C:\Python27\Lib\site-packages"
>> Thanks for info. Just keep in mind that what you did is not a clean way,
> although it will probably work for completion and docstrings. However,
> remember that still you should run scripts from the GRASS session (GUI or
> command line) and not directly from the editor.
> Anyway, setting PYTHONPATH to C:\Program Files (x86)\GRASS GIS
> 6.4.3RC2\etc\python\grass for your editor should work and it strange if it
> do not. But this can be editor/IDE dependent.
> Thanks again
>> milton
>> 2014/1/18 Milton Ribeiro <miltinho.astronauta at gmail.com>
>>> Dear Anna and Vaclav,
>>> thanks a lot for your kind reply.
>>> I tried to find grass.script to define de proper address where it is, or
>>> to copy this to my python/lib directory but I could'nt find.
>>> I am using window 8.
>>> Any hint are welcome.
>>> best
>>> milton
>>> 2014/1/17 Vaclav Petras <wenzeslaus at gmail.com>
>>>> On Fri, Jan 17, 2014 at 2:23 PM, Milton Ribeiro <
>>>>> Dear all,
>>>>> I would like to know if is there anyone using
>>>>> WingIDE python editor to write python grass scripting.
>>>>> I am using WingIDE under windows, but grass.scripting lib methods not
>>>>> autocomplete, and the help of grass.scripting not appears on WingIDE as for
>>>>> other libs of python.
>>>>> I'm not using WingIDE nor Windows, so I hope somebody else will reply,
>>>> too.
>>>> However, (for several reasons) grass.script is not installed to the
>>>> system (to the python installation), so you need to tell your IDE where to
>>>> look for the grass.scripting. One possibility is to set PYTHONPATH
>>>> environmental variable (which will then appear in sys.path in python) for
>>>> the IDE:
>>>> http://www.wingware.com/doc/intro/tutorial-python-path
>>>> Maybe there is some settings even directly in the editor. The path
>>>> should be set to the directory where grass.script, i.e. something like:
>>>> C:\path\to\grass\etc\python\
>>>> The way which works the best for me, on Ubuntu with Spyder Python IDE,
>>>> is starting the editor from within the GRASS session (GRASS command line).
>>>> This ensures that the environment is set right and you not only have the
>>>> autocomplete and documentation but also that you can run your python GRASS
>>>> scripts in the IDE. In theory, this should work the same on MS Windows.
>>>> Vaclav
>>>> best wishes
>>>>> Miltinho - mcr at rc.unesp.br
>>>>> Laboratório de Ecologia Espacial e Conservação - LEEC
>>>>> Depto de Ecologia - UNESP - Rio Claro
>>>>> Av. 24A, 1515- Bela Vista
>>>>> 13506-900 Rio Claro, SP, Brasil
>>>>> Fone: +55 19 3526-9647 (office) 19 3526-9680 (lab)
>>>>> Cel: 19 9853-3220 / 19 9853-5430
>>>>> Depto Ecologia http://ib.rc.unesp.br/#!/departamentos/ecologia/
>>>>> PG ECO & BIODIV
>>>>> http://ib.rc.unesp.br/#!/departamentos/ecologia/pos-graduacao-em-ecologia-e-biodiversidade/
>>>>> CV
>>>>> http://buscatextual.cnpq.br/buscatextual/visualizacv.do?id=K4792988H6&mostrarNroCitacoesISI=true&mostrarNroCitacoesScopus=true
>>>>> Google citations http://scholar.google.com/citations?user=OWX_2eAAAAAJ
>>>>> _______________________________________________
>>>>> grass-user mailing list
>>>>> grass-user at lists.osgeo.org
>>>>> http://lists.osgeo.org/mailman/listinfo/grass-user
>>> PG ECO & BIODIV
>>> CV
>> PG ECO & BIODIV
>> CV
PG ECO & BIODIV
CV
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20140118/94c56494/attachment.html>
