[GRASS-user] add a centroid in the center of polygon
Milton Ribeiro
miltinho.astronauta at gmail.com
Sat Jan 25 02:59:43 PST 2014
Thanks Markus,
Cheers
milton
2014/1/25 Markus Neteler <neteler at osgeo.org>
> On Sat, Jan 25, 2014 at 12:10 AM, Milton Ribeiro
> <miltinho.astronauta at gmail.com> wrote:
> > Dear all,
> > I have a polygon vector, and need to add point in the center of mass of
> each
> > one.
> > I used v.centroid, but it adds just a centroid, but not in the central
> > position of the polygon area.
> > any hint are welcome!
> I take liberty to cite a previous email here which is somewhat related:
> On Tue, Feb 28, 2012 at 8:48 PM, Hamish <hamish_b at yahoo.com> wrote:
> > Vishal wrote:
> >> i'm interested in estimating the centre of population of a city
> >> and how it might have changed in 10 years. i have a vector
> >> polygon layer for each year, which is the ward population.
> >> each layer has 198 polygons(wards) with population attributes
> >> for each polygon(ward). The distribution of population within
> >> a ward is not known, hence assumed uniform for now.
> >> is there a module in GRASS for calculating this. i know we can
> >> calculate geographic centroids, but was'nt sure if there was
> >> one for this kind of thing.
> >> Otherwise i could do it manually by extracting the geographic
> >> centroid of each polygon, then the coordinates of the
> >> population centre would be:
> >> xhat = sum(Pi Xi) /(sum(Pi)
> >> yhat = sum(Pi Yi) / sum(Pi)
> >> where Xi, Yi are each polygon i's geographic centroids; and
> >> Pi are each polygon's population coordinates are in UTM.
> > Hi,
> > This won't really answer your question, but fyi the centroid
> > position is calculated by Vect_find_poly_centroid() like this:
> http://trac.osgeo.org/grass/browser/grass/trunk/lib/vector/Vlib/poly.c#L309
> > but then tested to see if the point is within the polygon.
> > beware of "C" or "O" shaped wards, where the center of mass
> > (or the more simple center of the bounding box) may not be.
> > and if you did have population data instead of polygons there
> > is an addon script for that:
> > http://grass.osgeo.org/wiki/AddOns#v.points.cog
> > "v.points.cog is a shell script which will create a new point at
> > the center of gravity of each cluster of input points or
> > centroids, grouped by attribute. Among other things this is
> > useful for labeling swarms of points."
> (actual link:
> http://grasswiki.osgeo.org/wiki/AddOns/GRASS_6#v.points.cog
> > maybe it helps one day..
> > Hamish
> Due to the shape issue there is no general solution, it depends on the
> data.
> Maybe other list members have further suggestions.
> Markus
Miltinho - mcr at rc.unesp.br
Laboratório de Ecologia Espacial e Conservação - LEEC
Depto de Ecologia - UNESP - Rio Claro
Av. 24A, 1515- Bela Vista
13506-900 Rio Claro, SP, Brasil
Fone: +55 19 3526-9647 (office) 19 3526-9680 (lab)
Cel: 19 9853-3220 / 19 9853-5430
Depto Ecologia http://ib.rc.unesp.br/#!/departamentos/ecologia/
PG ECO & BIODIV
http://ib.rc.unesp.br/#!/departamentos/ecologia/pos-graduacao-em-ecologia-e-biodiversidade/
CV
http://buscatextual.cnpq.br/buscatextual/visualizacv.do?id=K4792988H6&mostrarNroCitacoesISI=true&mostrarNroCitacoesScopus=true
Google citations http://scholar.google.com/citations?user=OWX_2eAAAAAJ
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20140125/0670c57b/attachment.html>
