[GRASS-user] r.stats - wrong area values from MOLA dataset
Carlos Grohmann
carlos.grohmann at gmail.com
Tue Jul 1 09:40:58 PDT 2014
Hello all
I'm trying to get some stats for Mars using a MOLA dataset.
Since GRASS 7.0beta is having some problems with the most recent matplotlib
i added the planetary spheroids from v.7.0 into v.6.4.4 ellipse.table file.
Then I created a Location using Equirectangular (eqc) projection, no datum
definition (dx=dy=dz=0) and mars (IAU2000) spheroid.
After that I run, through python, r.stats and make a list of the area
values:
gdem = 'mola'
bwidth = 10 #10m bins for histogram
rinfo = grass.parse_command('r.info', map=gdem, flags='r')
g_min = float(rinfo['min'])
g_max = float(rinfo['max'])
grass.run_command('g.region', rast=gdem, flags='pa')
nbins = round((g_max - g_min)/bwidth) # bin size
mapstats = grass.read_command('r.stats', input = gdem, \
fs = ',', nsteps = nbins, flags = 'an')
histlist = mapstats.splitlines()
elevlist = []
arealist = []
for pair in histlist:
try:
pairlist = pair.split(',')
elev = int(float(pairlist[0]))
area = float(pair.split(',')[1])
elevlist.append(elev)
arealist.append(area)
except:
pass
np.sum(arealist)
this last step will give me:
>>> np.sum(arealist)
64793.652361588101
Of course this is wrong. Mars has a surface area of about 144.8E6km2. I
know that my steps are working because I get correct values for Earth:
#with ETOPO5 (r.stats returns values in m2)
>>> np.sum(arealist)/10e6
507756893328616.19
So, what am I missing?
thanks
Carlos
Prof. Carlos Henrique Grohmann
Institute of Energy and Environment - Univ. of São Paulo, Brazil
- Digital Terrain Analysis | GIS | Remote Sensing -
http://carlosgrohmann.com
http://orcid.org/0000-0001-5073-5572
________________
Can't stop the signal.
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20140701/8f49169c/attachment-0001.html>
