[GRASS-user] Error using v.rast.stats: "begin transaction"
Francesca Carisi
francesca.carisi at unibo.it
Tue Jul 8 05:35:12 PDT 2014
I'm quite new in using Grass, so maybe this is not a very complicate error.
I'm trying to use *v.rast.stats* to calculate statistics on a vector
poligon from a raster map, but I always receive this error:
v.rast.stats vector=samo_calc_v a samoggia raster=dem80 a samoggia
colprefix=elev
Updating the database ...
DBMI-DBF driver error:
ERROR: Errore durante l'esecuzione: 'BEGIN TRANSACTION'
The new columns were created but they're empty and the table of
attributes isn't corrupted.
Following the suggestion of a member of the Osgeo Team, I tried to
download this nc dataset
grass.osgeo.org/sampledata/north_carolina/nc_spm_latest.zip
<http://grass.osgeo.org/sampledata/north_carolina/nc_spm_latest.zip>
and I tried to do this, just to remove all doubt:
(Tue Jul 08 10:04:05 2014)
g.copy vect=zipcodes_wake,myzipcodes_wake
Copy vector <zipcodes_wake a PERMANENT> to current mapset as <myzipcodes_wake>
(Tue Jul 08 10:04:06 2014) Comando terminato (0 sec)
(Tue Jul 08 10:04:51 2014)
g.region rast=elevation -p
projection: 99 (Lambert Conformal Conic)
zone: 0
datum: nad83
ellipsoid: a=6378137 es=0.006694380022900787
north: 228500
south: 215000
west: 630000
east: 645000
nsres: 10
ewres: 10
rows: 1350
cols: 1500
cells: 2025000
(Tue Jul 08 10:04:51 2014) Comando terminato (0 sec)
(Tue Jul 08 10:11:27 2014)
v.rast.stats -c myzipcodes_wake raster=elevation colprefix=elev
(Tue Jul 08 10:11:36 2014) Comando terminato (9 sec)
The error remain.
I'm using Grass 6.4.4 on Windows 7, but if I make the same passages in
an other pc (always Windows 7, Grass 6.4.4), it works without problems.
Has anybody a suggestion about why does it happen and what to do?
All suggestions all welcome! Thanks!
Best regards,
Francesca
Francesca Carisi
PhD Student
Università di Bologna
Dip. DICAM - Costruzioni Idrauliche
Viale Risorgimento, 2 - 40136 Bologna (ITALY)
Tel: +39 051 20 93371
Fax: +39 051 20 93140
E-mail: francesca.carisi a unibo.it
Un allegato HTML ? stato rimosso...
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20140708/8cb62aa1/attachment.html>
