[GRASS-user] d.out.file format=png file malformed
Anna Petrášová
kratochanna at gmail.com
Fri Jul 18 12:00:15 PDT 2014
On Fri, Jul 18, 2014 at 1:56 PM, Dave Roberts <
dvrbts at ecology.msu.montana.edu> wrote:
> Friends,
> I'm using GRASS 70-svn on Arch linux to generate figures for a report.
> The general process is
> 1) GRASS - d.out.file format=png
> 2) xfig - import the PNG file, annotate, and export as PDF
> 3) TeX - import the file in a dvipdfm \special
> However, I'm now having problems with non-functional PNG files from
> d.out.file. Just below is a paste from my console. You can't see the
> error from inside xfig, but the line just below "xfig" is the stderr output
> from attempting to import demo_png.png.
> GRASS 7.0.svn > d.out.file out=demo_png.png format=png size=800,600
> Mapset <final> in Location <beartooth>
> GRASS 7.0.svn > xfig
> Warning: translation table syntax error: Missing '(' while parsing action
> sequence
> 'arning: ... found while parsing ':~Ctrl<Key>1: insert-string(1)
> Warning: String to TranslationTable conversion encountered errors
> libpng error: invalid file gamma in png_set_gamma
> The resulting PNG file will import into Imagemagick OK, and can then be
> exported back out as a PNG file which xfig will accept, so there is a work
> around, but maybe this is easily fixed? I've had a look at Anna's python
> script but haven't gone into the imported modules.
I have never had any problems with exported images from GRASS. d.out.file
uses the same mechanism as when you use the toolbar button in map display.
I tried to get the png into xfig and it didn't complain (xfig version
3.2.5b). Any other image processing tools have problems (e.g. gimp)?
Anna
> Thanks, Dave
> David W. Roberts office 406-994-4548
> Professor and Head FAX 406-994-3190
> Department of Ecology email droberts at montana.edu
> Montana State University
> Bozeman, MT 59717-3460
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20140718/f389faa5/attachment.html>
