[GRASS-user] Python + GRASS 6.4.3 + r.viewshed
Büro Seling
buero-seling at t-online.de
Mon Jul 21 04:33:16 PDT 2014
Am 21.07.2014 12:06, schrieb Helmut Kudrnovsky:
>> # the next line works only when the script es started from within the
> terminal window from the started GRASS session
>> #grass.run_command('r.viewshed', input = input_map, output = output_map,
>> coordinate=[2560807,5823616], obs_elev=100, max_dist=3000, overwrite=True)
> is GRASS_ADDON in the PATH?
> r.viewshed is an addon saved in the GRASS_ADDON folder and not in GISBASE;
> so if GRASS_ADDON isn't in PATH, r.viewshed may be not found.
> HTH
> best regards
> Helmut
> View this message in context: http://osgeo-org.1560.x6.nabble.com/Python-GRASS-6-4-3-r-viewshed-tp5152070p5152077.html
> Sent from the Grass - Users mailing list archive at Nabble.com.
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
Dear Helmut,
thanks for Your tipp.
And Yes the path is missing.
Could You please give me tipp how to phrase it correctly in the .py file?
I tried a few things, googled it, read a few things bu didn´t get it to work.
Here is a screenshot of my latest (dump) try and a print of the $GRASS_ADDON_PATH
pathproblem
Best Regards
Stefan
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20140721/5accda80/attachment-0001.html>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20140721/5accda80/attachment-0001.jpg>
