[GRASS-user] Obtaining long/lat data from GRASS points
Alex Mandel
tech_dev at wildintellect.com
Tue Jul 22 12:43:46 PDT 2014
I was thinking, v.out.ogr to either GPX or GPSBabel format
http://www.gdal.org/ogr_formats.html
Those formats should be easy to load onto a GPS.
Enjoy,
Alex
On 07/22/2014 12:32 PM, Micha Silver wrote:
> What you need is the v.to.db module. It takes an "option=" parameter which you
> set to "coor" and also add the "column=" parameter with the names of the
> database columns that will hold the long/lat coordinates.
> On 2014-07-22 22:14, cboscari at sbcglobal.net wrote:
>> Hi everyone,
>> Is there a way to obtain the long/lat of a point from GRASS? I need to import
>> some locations from a layer into a GPS and I do not see an easy way to do
>> this. Thanks for any help.
>> Chris
>> Sent from Windows Mail
