[GRASS-user] create a common colour scale
Daniel Victoria
daniel.victoria at gmail.com
Wed Jul 23 05:03:44 PDT 2014
Hi Raphael,
I do recommend upgrading and going the way Anna mentioned, especially if
you are dealing with a large number of maps. But if that is not an option
here are the steps I'd take:
1) run r.info -r on each map to get the min/max range
2) user r.colors with one of the maps and the rule option to set you color
table to that map. Your rules might look something like this
min_value red
(max - min)/2 yellow
max_value blue
end
-- by substituting the min / max in the above you get a colortable going
from red to blue with yellow in the middle
3) copy the color table you just set to the other maps using r.color rast
option. Take a look at r.color man page for more info
http://grass.osgeo.org/grass64/manuals/r.colors.html
Daniel
On Tue, Jul 22, 2014 at 11:46 PM, <Raphael.Viscarra-Rossel at csiro.au> wrote:
> Thank you Daniel and Anna for the suggestions.
> Daniel, I wonder how I might display the ‘common’ colour legend when
> visualising the maps?
> When the maps are visualised, the colour legend changes to the min max of
> the current map displayed.
> Anna, I use GRASS 6.4.2 – so I guess I should upgrade…
> Thank you again.
> Raphael.
> __________________________
> Raphael *VISCARRA ROSSEL* | Principal Research Scientist | CSIRO Land and
> Water | Bruce E. Butler Laboratory, Clunies Ross St, Black Mountain, Acton
> ACT 2601 | PO BOX 1666 Canberra ACT 2600 | t. +61 2 6246 5945 | m. +61
> 467 769 364 | Chair International Union of Soil Science Working Group on
> Proximal Soil Sensing | www.researcherid.com/rid/B-4061-2011 |
> scholar.google.com.au/citations?hl=en&user=KpJdvKEAAAAJ
> From: Anna Petrášová <kratochanna at gmail.com>
> Date: Wednesday, 23 July 2014 12:15 pm
> To: Daniel Victoria <daniel.victoria at gmail.com>
> Cc: "Viscarra Rossel, Raphael (L&W, Black Mountain)" <
> Raphael.Viscarra-Rossel at csiro.au>, grass <grass-user at lists.osgeo.org>
> Subject: Re: [GRASS-user] create a common colour scale
> Hi,
> in case you use GRASS 7, r.colors accepts multiple maps or a file with
> the map names. So this should do it:
> r.colors map=precip1,precip2,precip3 color=precipitation
> Also, have a look at temporal modules (GRASS 7 only). You can register
> the series of maps as a dataset (t.create, t.register) and then you can
> easily get the min, max values for the entire series and there is also
> t.rast.colors.
> Anna
> On Tue, Jul 22, 2014 at 9:41 PM, Daniel Victoria <
> daniel.victoria at gmail.com> wrote:
>> Hi Raphael,
>> This is what I did some time ago when I had the same problem
>> 1) Find out the overall minimun and maximum precipitation over all maps.
>> 2) Use r.colors with the rules option to compose a colortable that cover
>> my entire precip range.
>> 3) Apply the same colortable to all maps
>> 4) plot and be happy
>> Hope it helps
>> Daniel
>> On Tue, Jul 22, 2014 at 10:01 PM, <Raphael.Viscarra-Rossel at csiro.au>
>> wrote:
>>> Hello
>>> I wonder if anyone knows how to create a common colour scale for
>>> different raster maps?
>>> I want to display all six maps on the same page with the single colour
>>> scale but I cannot find how to do this in GRASS.
>>> More specifically, I have six raster maps of rainfall for different
>>> time periods (each has a different range of values) and I would like to
>>> display them all with the same colour scale. The colour scale needs to be
>>> constructed using the min and max values of the set of six maps (and not
>>> just individual maps.
>>> Will appreciate any input please. Thank you,
>>> Raphael.
>>> and Water | Bruce E. Butler Laboratory, Clunies Ross St, Black Mountain,
>>> Acton ACT 2601 | PO BOX 1666 Canberra ACT 2600 | t. +61 2 6246 5945 |
>>> m. +61 467 769 364 | Chair International Union of Soil Science Working
>>> Group on Proximal Soil Sensing | www.researcherid.com/rid/B-4061-2011 |
>>> grass-user mailing list
>>> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20140723/156dddd1/attachment-0001.html>
