[GRASS-user] Windows 7 32bit Grass and Python
Carolin von Groote
cvgb at geo.uni-augsburg.de
Thu Jul 24 13:45:03 PDT 2014
Hello,
now I’m getting closer to the problem (but still have no clue how to solve it). Actually grass seems to work - at least the g.list command works fine with python on the windows machine. The problem is the v.in.ogr command which returns -1073741511 as an error code. I tried Grass 6.4.3, Grass 6.4.4 and Grass 7.0 beta the error is the same every time (of course I updated the environmental settings).
Does anybody have an idea how to solve this? That would be great.
Thanks in advance
Caro
On 23 Jul. 2014, at 13:46 , Carolin von Groote-Bidlingmaier <Carolin.vonGroote-Bidlingmaier at geo.uni-augsburg.de> wrote:
> Dear Mailing List Readers,
> I have problems using grass gis with an external python script on windows 7 32bit. I don’t get any error messages but nothing happens in grass gis. I simply try to import a shapefile and nothing happens (but I have the same problem when trying to list all the existing files in my map set) Everything works fine on OS X so I assume it's not a matter of wrong python code. When I do that manually in grass everything works fine.
> Environmental settings:
> GISBASE: C:\Program Files\GRASS GIS 6.4.3
> GISRC: C:\Users\<myusername>\AppData\Roaming\GRASS6\grassrc6 (this file exists and has the following information:
> - GISDBASE: E:\data\grass_data
> - LOCATION_NAME: Amazon_Brazil
> - MAPSET: Amazon
> - GRASS_GUI: wxpython
> which is the correct grass-location)
> GRASS_SH: C:\Program Files\GRASS GIS 6.4.3\msys\bin\sh.exe
> LD_LIBRARY_PATH: C:\Program Files\GRASS GIS 6.4.3\lib
> PATH: besides other entries C:\Program Files\GRASS GIS 6.4.3\etc;C:\Program Files\GRASS GIS 6.4.3\lib;C:\Program Files\GRASS GIS 6.4.3\bin;C:\Program Files\GRASS GIS 6.4.3\extralib;C:\Program Files\GRASS GIS 6.4.3\msys\bin
> import grass.script as grass works. Are there any suggestions what I made wrong/forgot?
> Thanks a lot for your help,
> Caro
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20140724/85f1b99b/attachment.html>
