[GRASS-user] running grass commands in external IDE
Vaclav Petras wenzeslaus at gmail.com
Sat Jul 26 17:57:51 PDT 2014
On Fri, Jul 25, 2014 at 1:29 PM, Chad Ferguson <terrafergus at gmail.com>
wrote:
> sys.path.append(os.path.join(os.environ['GISBASE'], "etc", "python",
> "grass", "script"))
> import grass.script as grass
Since the import is `import grass` or similar, you have to add the
directory containing `grass` directory, i.e.:
sys.path.append(os.path.join(os.environ['GISBASE'], "etc", "python"))
By the way, my personal opinion is that
is a bad practice and should be avoided in a new code, the alternative is
not standardized but
import grass.script as gscript
should do.
Vaclav
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20140726/81c2ea07/attachment.html>
