[GRASS-user] execGRASS("r.diversity") Done. No rasters created (Large rasters)
Markus Neteler
neteler at osgeo.org
Tue Jul 29 06:19:37 PDT 2014
Hi Sandra,
On Fri, Jun 20, 2014 at 7:49 AM, Markus Neteler <neteler at osgeo.org> wrote:
> On Sat, Jun 14, 2014 at 9:21 AM, Sandra MacFadyen <sandramf at live.co.za> wrote:
>> I am using r.diversity (GRASS GIS 7.0.0svn build 60785 win32) through R (R version 3.0.2 win32) on Windows 7 64bit.
>> However, when running the same code on a larger image (cells=6746328) from my own location, although it reports Done, no rasters are created. If I subset the image (cells=1632830) and run it again its works (see # sub2Kruger # code and results below). So I'm guessing it is a memory issue?
I tried again, directly executing the r.li.simpson command and one of
those called by r.dversity:
# NC dataset
g.region -p rast=lsat5_1987_10 at landsat -a
r.li.simpson --o input=lsat5_1987_10 at landsat \
conf=conf_diversity_5.0 \
output=lsat5_1987_div__simpson_size_5.0
It consumes (too much) memory.
Debugging it a bit. valgrind suggests that something leaking here:
# raster/r.li/r.li.daemon/avl.c, line 204
long avl_to_array(avl_node * root, long i, AVL_table * a)
if (root != NULL) {
i = avl_to_array(root->left_child, i, a);
if (a == NULL)
G_fatal_error("avl, avl_to_array: null value");
else {
a[i] = G_malloc(sizeof(AVL_tableRow));
a[i]->k = root->key;
a[i]->tot = root->counter;
i++;
i = avl_to_array(root->right_child, i, a);
return i;
Memory is allocated in every call of avl_to_array() but perhaps not
properly freed later?
Any developer having an idea?
Markus
Type: application/octet-stream
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20140729/29c88357/attachment.obj>
