[GRASS-user] grass7 will not display raster
Raphael.Viscarra-Rossel at csiro.au
Wed Jul 30 04:30:31 PDT 2014
Hello Hamish,
I installed GRASS 7 (following Markus' hint to install GEOS frwk also).
GRASS7 and the GUI start and all seems fine until I try to display a raster map – it does not display.
I thought that it might be because the mapset was created in an older version of GRASS (6.4.2) but I started a new project and imported a raster into a new map set in G7 – still not displaying. I can draw a histogram of the raster data but I cannot view the map.
When I start GRASS7, I get the message below, but I do not know what it means.
I use a Mac. Will appreciate any help with this. Thank you.
Launching <wxpython> GUI in the background, please wait...
GRASS 7.0.0svn (rain):~ > objc[15362]: Class TSSandboxPrefs is implemented in both /Library/Frameworks/TSLicense.framework/Versions/A/TSLicense and /Library/QuickTime/Flip4Mac WMV Import.component/Contents/MacOS/Flip4Mac WMV Import. One of the two will be used. Which one is undefined.
objc[15362]: Class TSSandboxPrefs is implemented in both /Library/Frameworks/TSLicense.framework/Versions/A/TSLicense and /Library/QuickTime/Flip4Mac WMV Advanced.component/Contents/MacOS/Flip4Mac WMV Advanced. One of the two will be used. Which one is undefined.
Raphael.
From: Hamish <hamish.webmail at gmail.com<mailto:hamish.webmail at gmail.com>>
Date: Wednesday, 30 July 2014 5:09 pm
To: "Viscarra Rossel, Raphael (L&W, Black Mountain)" <Raphael.Viscarra-Rossel at csiro.au<mailto:Raphael.Viscarra-Rossel at csiro.au>>
Cc: "grass-user at lists.osgeo.org<mailto:grass-user at lists.osgeo.org>" <grass-user at lists.osgeo.org<mailto:grass-user at lists.osgeo.org>>
Subject: Re: [GRASS-user] create a common colour scale
Raphael wrote:
thank you for the response and the hints.
no worries
They are very useful as i cannot get GRASS7 to work.
what's the trouble? maybe we can help.
regards,
Hamish
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20140730/aadf98bb/attachment.html>
