[GRASS-user] Suggested workflow for Importing DXF Wind Turbines onto Map in Grass 6.4.4
Paul Shapley
p.shapley at gmail.com
Wed Jul 30 13:57:31 PDT 2014
I have imported a single wind turbine (dxf) into grass with v.in.dxf
successfully. I need to position it on a map but do not know where to
start.
>From the grasswiki pages it says it is best to use XY location but how do
you assign known location co-ordinates to the base of a wind turbine
(without a copy of AutoCAD). I would also need to add many more wind
turbines onto the same map.Do i need to use v.proj/v.transform/v.rectify?
I might also need to set the height of the turbine but again not sure which
is the best action.
Thanks,
*Paul J. Shapley *MSc CGeog (GIS) FRGS
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20140730/246c3975/attachment-0001.html>
