[GRASS-user] Apparent missing elevation values
Crutchley, Simon
Simon.Crutchley at english-heritage.org.uk
Wed Jun 11 01:44:28 PDT 2014
HI Anna,
I only had one map 149683_JJ open, so I don’t think that’s the problem.
Ta
Simon
From: Anna Petrášová [mailto:kratochanna at gmail.com]
Sent: 10 June 2014 22:00
To: Micha Silver
Cc: Crutchley, Simon; grass-user at lists.osgeo.org
Subject: Re: [GRASS-user] Apparent missing elevation values
On Tue, Jun 10, 2014 at 3:43 PM, Micha Silver <micha at arava.co.il<mailto:micha at arava.co.il>> wrote:
On 10-Jun-14 7:35 PM, Crutchley, Simon wrote:
I'm new to GRASS. I've tried using my own data and am hitting a problem I don't understand. I've an elevation dataset with values ranging from 36-98m. The histogram shows a range of values. When I run profile analysis it says every point is 45.5m. Screen dumps show my data with the histogram and profile (NFor) as well as that for the test dataset (NCar). Am I doing something basic wrong?
Can we see your region settings, and the elevation raster info?
g.region -p
and
r.info<http://r.info> <your raster>
Could you check that you are profiling the correct raster map? It's not visible from the pictures. In the profile tool, click on one of the first buttons on the toolbar, to set the correct map.
Anna
grass-user mailing list
grass-user at lists.osgeo.org<mailto:grass-user at lists.osgeo.org>
http://lists.osgeo.org/mailman/listinfo/grass-user
This e-mail (and any attachments) is confidential and may contain personal views which are not the views of English Heritage unless specifically stated. If you have received it in error, please delete it from your system and notify the sender immediately. Do not use, copy or disclose the information in any way nor act in reliance on it. Any information sent to English Heritage may become publicly available.
Portico: your gateway to information on sites in the National Heritage Collection; have a look and tell us what you think.
http://www.english-heritage.org.uk/professional/archives-and-collections/portico/
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20140611/ad397a97/attachment.html>
