[GRASS-user] Question about v.to.rast
    Thomas Adams
    tea3rd at gmail.com
    Mon Jun 16 05:04:01 PDT 2014
Margherita,
Thank you for the suggestion; yes, the raster pixels are at the resolution
of the raster map, so the r.to.vect conversion is creating vector polygons
of the size of the individual raster pixels. If I can aggregate all of the
raster pixels using r.area, then that should do what I want, I think.
Cheers!
Tom
On Mon, Jun 16, 2014 at 7:55 AM, Margherita Di Leo <diregola at gmail.com>
wrote:
> Hi Thomas,
> On Mon, Jun 16, 2014 at 1:47 PM, Thomas Adams <tea3rd at gmail.com> wrote:
>> All:
>> I have used r.lake to simulate flood inundation in an urban area -- the
>> raster looks great! What I want to do (and have done) is to use r.to.vect,
>> export the vector as a KML (which works), bring the simulated flood
>> inundation map KMLs into GoogleEarth and create some animations from the
>> simulated inundation, including showing rising flood levels inundating the
>> city streets in 3D.
>> I can basically do all this, except that the r.to.vect conversion creates
>> a gazillion boxes that are the size of the raster pixels -- I don't want
>> all the tiny boxes.
> I'm not sure I understand correctly, but if the tiny pixels are there also
> in the raster map, might be useful r.area (addon) [1].
> Hope this helps,
> Cheers,
> madi
>> What I want, is just a single (albeit, complex) polygon showing the
>> flooded areas. v.dissolve will remove the boundaries of adjacent boxes if
>> their cat or attributes are the same -- is this the way to go, namely, make
>> all the cats or attribute values the same and then use v.dissolve?
>> Or, is there is there a better way to do what I'm attempting to do? That
>> is, is it best to keep the individual small vector boxes for reasons I'm
>> not considering?
>> Thank you,
>> Tom
>> [1] http://grass.osgeo.org/grass70/manuals/addons/r.area.html
> Best regards,
> Dr. Margherita DI LEO
> Scientific / technical project officer
> European Commission - DG JRC
> Institute for Environment and Sustainability (IES)
> Via Fermi, 2749
> I-21027 Ispra (VA) - Italy - TP 261
> Tel. +39 0332 78 3600
> margherita.di-leo at jrc.ec.europa.eu
> Disclaimer: The views expressed are purely those of the writer and may not
> in any circumstance be regarded as stating an official position of the
> European Commission.
Thomas E Adams, III
718 McBurney Drive
Lebanon, OH 45036
1 (513) 739-9512 (cell)
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20140616/7790b8bc/attachment-0001.html>
