[GRASS-user] i.segment
    Francesco Nex
    franex at fbk.eu
    Mon Jun 30 03:09:39 PDT 2014
My name is Francesco and I'm very new with GRASS.
I tried to use the i.segment command and I got a problem.
The command lines I used are the following:
i.segment -d group=060140_file_OFD output=060140_file_segs_L1 threshold=0.1
i.segment -d group=060140_file_OFD output=060140_file_segs_L2 threshold=0.2
seeds=060140_file_segs_L1 min=2
the lines are very similar to the example provided in the tutorial:
http://grass.osgeo.org/grass70/manuals/i.segment.html
Anyway, when I run the second line, the output window return the following
message:
WARNING: Region consists of only one cell, nothing to update
and the process doesn't run.
I tried to change the parameters, but the result was always the same.
What is my mistake?
Thank you!
Francesco
_______________________________________________________
*Francesco Nex*, PhD
3D Optical Metrology Unit (3DOM)
Bruno Kessler Foundation (FBK), Via Sommarive 18, 38123, Trento
Telephone: 0461 3146150461 314615
Web: http://3dom.fbk.eu/en/nex
Call
Send SMS
Add to Skype
You'll need Skype CreditFree via Skype
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20140630/bd6505d9/attachment.html>
