[GRASS-user] Problems to launch GRASS in OSX 10.6.8 (Snow Leopard)
José Carlos Guerrero Antúnez
jcgantunez at gmail.com
Tue Mar 11 07:11:42 PDT 2014
Yes, and it's displayed the following:
'/Applications/GRASS-6.4.app/Contents/MacOS/grass.sh'; exit
Last login: Tue Mar 11 10:01:14 on console
102:~ joseca_IMac$ '/Applications/GRASS-6.4.app/Contents/MacOS/grass.sh';
exit
Rebuilding Addon HTML manual pages index...
Rebuilding Addon menu...
Python 2.6.1 found.
Cleaning up temporary files ...
Starting GRASS ...
access: No such file or directory
ERROR: LOCATION <<
/var/folders/ZI/ZILrLuSdG3uvcRwKJxojRU+++TI/-Tmp-/processing/grassdata/temp_location
>> not available
GRASS 6.4.3
DATABASE: A directory (folder) on disk to contain all GRASS maps and data.
LOCATION: This is the name of a geographic location. It is defined by a
co-ordinate system and a rectangular boundary.
MAPSET: Each GRASS session runs under a particular MAPSET. This consists
of
a rectangular REGION and a set of maps. Every LOCATION contains at
least a MAPSET called PERMANENT, which is readable by all
sessions.
The REGION defaults to the entire area of the chosen LOCATION.
You may change it later with the command: g.region
LOCATION: temp_location____________ (enter list for a list of locations)
MAPSET: PERMANENT________________ (or mapsets within a location)
DATABASE:
When I write LOCATION and MAPSET, it's the message:
DATABASE
</var/folders/ZI/ZILrLuSdG3uvcRwKJxojRU+++TI/-Tmp-/processing/grassdata> -
not found
HIT RETURN
2014-03-11 11:01 GMT-03:00 William Kyngesburye <woklist at kyngchaos.com>:
> Does Terminal.app start?
> On Mar 6, 2014, at 1:58 PM, José Carlos Guerrero Antúnez wrote:
> > Hi,
> > When I launch GRASS GIS, must be appear the startup screen, but doesn't
> open it.
> > All plugin are updated, I installed GRASS today from kynchaos web.
> > Any help/advice?,
> > Thank you,
> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> http://www.kyngchaos.com/
> Theory of the Universe
> There is a theory which states that if ever anyone discovers exactly what
> the universe is for and why it is here, it will instantly disappear and be
> replaced by something even more bizarrely inexplicable. There is another
> theory which states that this has already happened.
> -Hitchhiker's Guide to the Galaxy 2nd season intro
Dr. José Carlos Guerrero
Laboratorio de Desarrollo Sustentable y Gestión Ambiental del Territorio
(LDSGAT)
Instituto de Ecología y Ciencias Ambientales (IECA)
Facultad de Ciencias
Universidad de la República
Montevideo-URUGUAY
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20140311/8e1ff705/attachment.html>
