[GRASS-user] Problems to launch GRASS in OSX 10.6.8 (Snow Leopard)
José Carlos Guerrero Antúnez
jcgantunez at gmail.com
Tue Mar 11 07:37:40 PDT 2014
Thank you William!!
Now it's Ok.
2014-03-11 11:33 GMT-03:00 William Kyngesburye <woklist at kyngchaos.com>:
> I see what's happening - when you use the QGIS Processing plugin, it
> creates a temporary DATABASE path to do its work. GRASS.app remembers
> this, but since it's temporary within QGIS, it no longer exists for
> GRASS.app.
> When you use GRASS.app by itself, you need to fill in the DATABASE also.
> Alternately, drag the MAPSET folder onto GRASS.app to start GRASS, it will
> automatically open the mapset and fill in the correct LOCATION and DATABASE
> path.
> On Mar 11, 2014, at 9:11 AM, José Carlos Guerrero Antúnez wrote:
> > Yes, and it's displayed the following:
> > '/Applications/GRASS-6.4.app/Contents/MacOS/grass.sh'; exit
> > Last login: Tue Mar 11 10:01:14 on console
> > 102:~ joseca_IMac$
> > Rebuilding Addon HTML manual pages index...
> > Rebuilding Addon menu...
> > Python 2.6.1 found.
> > Cleaning up temporary files ...
> > Starting GRASS ...
> > access: No such file or directory
> > ERROR: LOCATION <<
> /var/folders/ZI/ZILrLuSdG3uvcRwKJxojRU+++TI/-Tmp-/processing/grassdata/temp_location
> > >> not available
> > GRASS 6.4.3
> > DATABASE: A directory (folder) on disk to contain all GRASS maps and
> data.
> > LOCATION: This is the name of a geographic location. It is defined by a
> > co-ordinate system and a rectangular boundary.
> > MAPSET: Each GRASS session runs under a particular MAPSET. This
> consists of
> > a rectangular REGION and a set of maps. Every LOCATION
> contains at
> > least a MAPSET called PERMANENT, which is readable by all
> sessions.
> > The REGION defaults to the entire area of the chosen LOCATION.
> > You may change it later with the command: g.region
> > LOCATION: temp_location____________ (enter list for a list of
> locations)
> > MAPSET: PERMANENT________________ (or mapsets within a location)
> > DATABASE:
> > When I write LOCATION and MAPSET, it's the message:
> > DATABASE
> </var/folders/ZI/ZILrLuSdG3uvcRwKJxojRU+++TI/-Tmp-/processing/grassdata> -
> not found
> > HIT RETURN
> > 2014-03-11 11:01 GMT-03:00 William Kyngesburye <woklist at kyngchaos.com>:
> > Does Terminal.app start?
> > On Mar 6, 2014, at 1:58 PM, José Carlos Guerrero Antúnez wrote:
> > > Hi,
> > > When I launch GRASS GIS, must be appear the startup screen, but
> doesn't open it.
> > > All plugin are updated, I installed GRASS today from kynchaos web.
> > > Any help/advice?,
> > > Thank you,
> > William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> > http://www.kyngchaos.com/
> > Theory of the Universe
> > There is a theory which states that if ever anyone discovers exactly
> what the universe is for and why it is here, it will instantly disappear
> and be replaced by something even more bizarrely inexplicable. There is
> another theory which states that this has already happened.
> > -Hitchhiker's Guide to the Galaxy 2nd season intro
> > Dr. José Carlos Guerrero
> > Laboratorio de Desarrollo Sustentable y Gestión Ambiental del Territorio
> (LDSGAT)
> > Instituto de Ecología y Ciencias Ambientales (IECA)
> > Facultad de Ciencias
> > Universidad de la República
> > Montevideo-URUGUAY
> > grass-user mailing list
> > grass-user at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/grass-user
> [Trillian] What are you supposed to do WITH a maniacally depressed robot?
> [Marvin] You think you have problems? What are you supposed to do if you
> ARE a maniacally depressed robot? No, don't try and answer, I'm 50,000
> times more intelligent than you and even I don't know the answer...
> - HitchHiker's Guide to the Galaxy
(LDSGAT)
Montevideo-URUGUAY
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20140311/65642dc6/attachment.html>
