[GRASS-user] Building -7.0 Fails
Rich Shepard rshepard at appl-ecosys.com
Sat Mar 15 10:24:16 PDT 2014
On Sat, 15 Mar 2014, Vaclav Petras wrote:
> This you should get when the build fails. In other words, the make always
> prints a report at the end with the message whether the compilation was
> successful or it prints a list of directories where the compilation
> failed.
Vaclav,
   The tail of that list of directories was what I copied into the original
message. In addition, here's the error.log:
GRASS GIS 7.0.svn 59253 compilation log
Started compilation: Fri Mar 14 08:51:04 PDT 2014
Errors in:
/home/rshepard/GIS/GRASS/grass-7.0svn/scripts/i.pansharpen
/home/rshepard/GIS/GRASS/grass-7.0svn/temporal/t.create
/home/rshepard/GIS/GRASS/grass-7.0svn/temporal/t.support
/home/rshepard/GIS/GRASS/grass-7.0svn/temporal/t.topology
/home/rshepard/GIS/GRASS/grass-7.0svn/temporal/t.list
/home/rshepard/GIS/GRASS/grass-7.0svn/temporal/t.info
/home/rshepard/GIS/GRASS/grass-7.0svn/temporal/t.merge
/home/rshepard/GIS/GRASS/grass-7.0svn/temporal/t.remove
/home/rshepard/GIS/GRASS/grass-7.0svn/temporal/t.sample
/home/rshepard/GIS/GRASS/grass-7.0svn/temporal/t.register
/home/rshepard/GIS/GRASS/grass-7.0svn/temporal/t.unregister
/home/rshepard/GIS/GRASS/grass-7.0svn/temporal/t.rast.accumulate
/home/rshepard/GIS/GRASS/grass-7.0svn/temporal/t.rast.accdetect
/home/rshepard/GIS/GRASS/grass-7.0svn/temporal/t.rast.aggregate
/home/rshepard/GIS/GRASS/grass-7.0svn/temporal/t.rast.aggregate.ds
/home/rshepard/GIS/GRASS/grass-7.0svn/temporal/t.rast.colors
/home/rshepard/GIS/GRASS/grass-7.0svn/temporal/t.rast.to.rast3
/home/rshepard/GIS/GRASS/grass-7.0svn/temporal/t.rast.univar
/home/rshepard/GIS/GRASS/grass-7.0svn/temporal/t.rast.list
/home/rshepard/GIS/GRASS/grass-7.0svn/temporal/t.rast.mapcalc
/home/rshepard/GIS/GRASS/grass-7.0svn/temporal/t.rast.mapcalc2
/home/rshepard/GIS/GRASS/grass-7.0svn/temporal/t.rast.neighbors
/home/rshepard/GIS/GRASS/grass-7.0svn/temporal/t.rast.series
/home/rshepard/GIS/GRASS/grass-7.0svn/temporal/t.rast.export
/home/rshepard/GIS/GRASS/grass-7.0svn/temporal/t.rast.out.vtk
/home/rshepard/GIS/GRASS/grass-7.0svn/temporal/t.rast.import
/home/rshepard/GIS/GRASS/grass-7.0svn/temporal/t.rast.gapfill
/home/rshepard/GIS/GRASS/grass-7.0svn/temporal/t.rast.extract
/home/rshepard/GIS/GRASS/grass-7.0svn/temporal/t.rast3d.list
/home/rshepard/GIS/GRASS/grass-7.0svn/temporal/t.rast3d.extract
/home/rshepard/GIS/GRASS/grass-7.0svn/temporal/t.rast3d.mapcalc
/home/rshepard/GIS/GRASS/grass-7.0svn/temporal/t.rast3d.mapcalc2
/home/rshepard/GIS/GRASS/grass-7.0svn/temporal/t.rast3d.univar
/home/rshepard/GIS/GRASS/grass-7.0svn/temporal/t.rename
/home/rshepard/GIS/GRASS/grass-7.0svn/temporal/t.select
/home/rshepard/GIS/GRASS/grass-7.0svn/temporal/t.snap
/home/rshepard/GIS/GRASS/grass-7.0svn/temporal/t.shift
/home/rshepard/GIS/GRASS/grass-7.0svn/temporal/t.vect.list
/home/rshepard/GIS/GRASS/grass-7.0svn/temporal/t.vect.db.select
/home/rshepard/GIS/GRASS/grass-7.0svn/temporal/t.vect.export
/home/rshepard/GIS/GRASS/grass-7.0svn/temporal/t.vect.extract
/home/rshepard/GIS/GRASS/grass-7.0svn/temporal/t.vect.mapcalc
/home/rshepard/GIS/GRASS/grass-7.0svn/temporal/t.vect.import
/home/rshepard/GIS/GRASS/grass-7.0svn/temporal/t.vect.what.strds
/home/rshepard/GIS/GRASS/grass-7.0svn/temporal/t.vect.observe.strds
/home/rshepard/GIS/GRASS/grass-7.0svn/temporal/t.vect.univar
/home/rshepard/GIS/GRASS/grass-7.0svn/gui/wxpython/animation
/home/rshepard/GIS/GRASS/grass-7.0svn/gui/wxpython/mapswipe
/home/rshepard/GIS/GRASS/grass-7.0svn/gui/wxpython/gmodeler
/home/rshepard/GIS/GRASS/grass-7.0svn/gui/wxpython/rlisetup
/home/rshepard/GIS/GRASS/grass-7.0svn/gui/wxpython/psmap
/home/rshepard/GIS/GRASS/grass-7.0svn/gui/wxpython/dbmgr
/home/rshepard/GIS/GRASS/grass-7.0svn/gui/wxpython/vdigit
/home/rshepard/GIS/GRASS/grass-7.0svn/gui/wxpython/iclass
/home/rshepard/GIS/GRASS/grass-7.0svn/gui/wxpython/gcp
/home/rshepard/GIS/GRASS/grass-7.0svn/gui/wxpython/timeline
In case of errors please change into the directory with error and run 'make'.
If you get multiple errors, you need to deal with them in the order they
appear in the error log. If you get an error building a library, you will
also get errors from anything which uses the library.
Finished compilation: Fri Mar 14 08:59:47 PDT 2014
   Mea culpa! I had not looked at the error.log before. Now I see that
nothing in 7.0 is building here.
   Suggestions on where I should start looking for why?
Rich
Richard B. Shepard, Ph.D.          |      Have knowledge, will travel.
Applied Ecosystem Services, Inc.   |
www.appl-ecosys.com      Voice: 503-667-4517         Fax: 503-667-8863
