[GRASS-user] r.resamp.rst - ERROR: Input window changed while maps are open for read.
Tue Mar 18 03:39:50 PDT 2014
Markus Neteler wrote:
> > the issue is still there. I get the same error message. Using the stable
> > version of GRASS (6.4) is not an option for me since I am working with very
> > large files (>2GB) for which this module returns the error described  here
> > <http://trac.osgeo.org/grass/ticket/1786>  .
> The ticket reports on r.resamp.rst in GRASS 6. We cannot fix it there
> easily since many libraries are involved (see ticket).
> Does the problem also exist in GRASS 7 for you?
> You can install it in parallel to GRASS 6, see
> http://grass.osgeo.org/download/software/linux/#grass70
In 6.x, the tempfile code in the RST library is limited to 2 GiB
(ticket #1786).
In 7.x, the RST library isn't working because it hasn't been updated
for the new raster window handling (r40772 etc) (ticket #1718).
