[GRASS-user] Questions concerning r.mapcalc, r.cost and high resolution DEMs
Juan Carlos Torres
jctorres at ugr.es
Mon Mar 24 03:00:22 PDT 2014
Daniel
For the first problem I would sugest you to filter high slope values
r.mapcalc h_m=if(slope<70, (0.000166666*(exp(3.5*(abs(tan(
"slope_in_degree" )+0.05)))))*cellsize, null())
For the second problem, did you try to use a smaller percentage (say 10%)?
best regards
El 24/03/14 10:15, Daniel Becker escribió:
> Hello,
> i just joined this mailing list and i hope i'm doing everything right.
> I'm in a project where i try to provide an easy way to do a
> cost-distance analysis, based on a given raster DEM, i did this with
> ArcGIS earlier but i want more people to be able to use this simple
> (and faster) approach, but i ran into some problems.
> The workflow looks like this:
> DEM -> slope -> r.mapcalc(tobler hiking function) -> cost raster ->
> r.cost -> cost distance raster -> contours that represent walking
> distance from a given point.
> The function i use in r.mapcalc
> is: h/m=(0.000166666*(exp(3.5*(abs(tan( "slope_in_degree"
> The problems i ran into:
> 1. This works with SRTM-data, but if i use a higher resolution DEM
> (10m), the resulting cost raster contains some infinite values and
> the r.cost tool doesn't really work anymore
> * Is there a way to adress "inf" in r.mapcalc? I can just filter
> everything > 500, but that isn't really satisfying. :)
> * I don't really know what the underlying problem is, exp()
> leads to the infinite values, but maybe there is a way to
> filter those extreme slopes earlier or in the DEM (although
> the slope raster contains only values <90°)?
> 2. ERROR: G_malloc: unable to allocate 524288 bytes of memory at
> setup.c:64 - happens at 144.024.001 pixels (merged SRTM-DEM of
> Spain) and above if i don't set "Percent of map to keep in memory"
> to quite low values of below 20-30%, although neither my RAM nor
> the harddrive with the .tmp-folder is fully utilized. The problem
> is: What happens at even higher pixelcounts?
> 3. This may be the wrong place for this but: Usability-wise it would
> be even nicer to use QGIS and its modelbuilder for this approach.
> The problem is that the parameters for stop_point or
> stop_coordinate can't stay empty in the QGIS-GUI (which it has to
> be, since the whole raster should be processed). Maybe there is a
> way to work around this?
> So, i'd be happy if someone could help me. Here is also an example
> (https://www.dropbox.com/s/i6rsm9v9p7gwfx2/01_isochronen_arroyotobler_ardales.png) of
> what i'm trying to do, so that it's less abstract. :-)
> Thanks in advance and have a nice week
> Daniel
> grass-user mailing list
> grass-user en lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-user
Juan Carlos Torres | http://lsi.ugr.es/~jctorres
Laboratorio de Realidad Virtual | Tlf.: (+34) 645 885 167
Dpto. Lenguajes y Sistemas Informaticos | (+34) 958 249 307
ETS. Ing. Informatica | interno ugr 71 260
Univ. de Granada | FAX: (+34) 958 243 179
------------ pr?xima parte ------------
Se ha borrado un adjunto en formato HTML...
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20140324/ee413053/attachment.html>
