[GRASS-user] projection issue
Vincent Bain
bain at toraval.fr
Mon Mar 24 03:33:58 PDT 2014
Hello,
the trouble I am currently experiencing is dealing partly with cs2cs,
but partly with grass, so I post my question on this list...
Being within a Mercator location, defined with the location wizard
(calling epsg:3857), I type :
echo "6.46311951 45.78037144" | m.proj -idg
input parameters=[+proj=longlat +datum=WGS84]
output parameters=[+proj=merc +lat_ts=0.0 +lon_0=0.0 +x_0=0.0
+y_0=0 +k=1.0
+no_defs +a=6378137 +rf=298.257223563 +towgs84=0.000,0.000,0.000
+to_meter=1]
Which results in :
719471.17278927|5714587.81400429|0.00000000
The thing is this set of geographic coordinates should return something
else...
echo "6.46311951 45.78037144" | cs2cs +proj=longlat -f "%.8f"
+to +init=epsg:3857
gives :
719471.17278927 5745223.17292760 0.00000000
I guess this is not a m.proj issue, because passing projection argument
directly to cs2cs gives the same error :
curproj=`eval g.proj -jf`
+to $curproj
returns :
719471.17278927 5714587.81400429 0.00000000
I can't figure what is going wrong. Would anyone have an idea ?
Thanks,
Vincent
