[GRASS-user] the map does not render
Nikas Nikolas
nikasnikolas at gmail.com
Tue Mar 25 03:49:29 PDT 2014
Dear all, please give some advice.
The map doesn't render, but when I move the cursor the coordinates are
changing. When I the "set computational regions" I get the
*Command 'd.rast map=ninety at chdet' failed*
The display projection command gives this result
*g.proj -p*
-PROJ_INFO-------------------------------------------------
proj : tmerc
ellps : grs80
lat_0 : 0
lon_0 : 24
k : 0.9996
x_0 : 500000
y_0 : 0
towgs84 : -199.87,74.79,246.62,0,0,0,0
no_defs : defined
-PROJ_UNITS------------------------------------------------
unit : metre
units : metres
meters : 1
and when I choose metadata I get all the information
*r.info <http://r.info> map*=ninety at chdet
| Layer: ninety at chdet Date: Thu Mar 06 17:22:58 2014
| Mapset: chdet Login of Creator: gounaridis.d
| DataBase: H:\GRASSDATA
| Title: ( ninety )
| Timestamp: none
| Type of Map: raster Number of Categories: 4
| Data Type: CELL
| Rows: 584
| Columns: 632
| Total Cells: 369088
| Projection: Transverse Mercator
| N: 4204475.77974522 S: 4186371.77974522 Res: 31
| E: 502018.59283775 W: 482426.59283775 Res: 31
| Range of data: min = 1 max = 4
| Data Description:
| generated by r.in.gdal
| Comments:
| r.in.gdal -o input="D:\mathima1\master\SIGIS\SIGIS\LUCC\DATA\sigisas\
| k1\cl1990\hdr.adf" output="ninety"
*System Info *
GRASS version: 6.4.3
GRASS SVN Revision:
GIS Library Revision: 50937 (2012-02-25)
GDAL/OGR: 1.10.1
PROJ4: Rel. 4.8.0, 6 March 2012
Python: 2.7.5
wxPython: 2.8.12.1
Platform: Windows-8-6.2.9200 (OSGeo4W)
Thank you for your time
NN
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20140325/9a3da41c/attachment-0001.html>
