[GRASS-user] 6.5svn Build Problem
Rich Shepard
rshepard at appl-ecosys.com
Thu Mar 27 17:34:35 PDT 2014
I've not before had 6.5svn throw an error when building. After updating to
the latest modules in the repository I configured and built the application.
There was a build error in ../gui/wxpython so I cd'd to that subdirectory
and ran make. From the base directory I ran 'make install', then tried
invoking GRASS only to see this error:
Cleaning up temporary files ...
Starting GRASS ...
ERROR: wxGUI requires wxPython. No module named wxversion
Error in GUI startup. If necessary, please
report this error to the GRASS developers.
wxPython-2.8.12.1 is installed. But, indeed, there is nothing named
'wxversion' on this system. The -6.5svn source tree shows attempts to import
wxversion in:
grass6_devel/gui/wxpython/core/globalvar.py: import wxversion
grass6_devel/gui/wxpython/core/globalvar.py: #
wxversion.select(str(minVersion[0]) + '.' + str(minVersion[1]))
wxversion.ensureMinimal(str(minVersion[0]) + '.' + str(minVersion[1]))
grass6_devel/gui/wxpython/core/globalvar.py: except (ValueError,
wxversion.VersionError), e:
grass6_devel/gui/wxpython/README: lib64wxPythonGTK2.8
lib64wxPythonGTK2.8-devel wxPythonGTK wxPythonGTK-wxversion
grass6_devel/.svn/pristine/1b/1b81bbe95f076b38a9707473beb875f3eebde6f5.svn-base:
lib64wxPythonGTK2.8 lib64wxPythonGTK2.8-devel wxPythonGTK
grass6_devel/.svn/pristine/f1/f1efdd5e9fed65bd04ef8cd00ef8471c93502320.svn-base:
import wxversion
# wxversion.select(str(minVersion[0]) + '.' + str(minVersion[1]))
# wxversion.ensureMinimal(str(minVersion[0]) + '.' + str(minVersion[1]))
# except (ValueError, wxversion.VersionError), e:
gui/wxpython/core/globalvar.py: # wxversion.select(str(minVersion[0])
gui/wxpython/README: lib64wxPythonGTK2.8 lib64wxPythonGTK2.8-devel
Where do you suggest I start looking for the source of this error?
Thanks,
Rich
Richard B. Shepard, Ph.D. | Have knowledge, will travel.
Applied Ecosystem Services, Inc. |
www.appl-ecosys.com Voice: 503-667-4517 Fax: 503-667-8863
