[GRASS-user] 6.5svn Build Problem
Rich Shepard
rshepard at appl-ecosys.com
Fri Mar 28 15:03:30 PDT 2014
On Thu, 27 Mar 2014, Rich Shepard wrote:
> I've not before had 6.5svn throw an error when building.
OK, wxPython-3.0.0.0 installed and version.py is present. So, ...
From the main grass-6.5svn/ directory's error.log:
GRASS GIS compilation log
Started compilation: Fri Mar 28 14:34:50 PDT 2014
Errors in:
/home/rshepard/GIS/GRASS/grass-6.5svn/gui/wxpython
In case of errors please change into the directory with error and run 'make'.
If you get multiple errors, you need to deal with them in the order they
appear in the error log. If you get an error building a library, you will
also get errors from anything which uses the library.
Finished compilation: Fri Mar 28 14:44:19 PDT 2014
In ../gui/wxpython/ I run 'make' and see this output:
make parsubdirs
make[1]: Entering directory /home/rshepard/GIS/GRASS/grass-6.5svn/gui/wxpython'
make -C docs || echo /home/rshepard/GIS/GRASS/grass-6.5svn/gui/wxpython/docs >> /home/rshepard/GIS/GRASS/grass-6.5svn/error.log
make[2]: Entering directory /home/rshepard/GIS/GRASS/grass-6.5svn/gui/wxpython/docs'
for file in wxGUI wxGUI.PsMap wxGUI.Vector_Digitizer wxGUI.Components wxGUI.Modeler wxGUI.GCP_Manager wxGUI.Nviz wxGUI.Attribute_Table_Manager ; do \
rm -f $file.tmp.html ; \
rm -f "/home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu/docs/html/$file.html"; \
make htmldir PGM=$file; \
done
make[3]: Entering directory /home/rshepard/GIS/GRASS/grass-6.5svn/gui/wxpython/docs'
make /home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu/docs/html/wxGUI.html
make[4]: Entering directory /home/rshepard/GIS/GRASS/grass-6.5svn/gui/wxpython/docs'
if [ "" != "" ] ; then GISRC=/home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu/demolocation/.grassrc65 GISBASE=/home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu PATH="/home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu/bin:$PATH" LD_LIBRARY_PATH="/home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu/bin:/home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu/lib:/usr/lib/qt/lib:/usr/lib/qt/lib:" LC_ALL=C --html-description < /dev/null | grep -v '</body>\|</html>' > wxGUI.tmp.html ; true ; fi
../../../tools/mkhtml.sh wxGUI ; mkdir -p /home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu/docs/html ; /usr/bin/ginstall -c -m 644 wxGUI.tmp.html /home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu/docs/html/wxGUI.html ; for file in *.png *.jpg ; do head -n 1 $file | grep '^#!' > /dev/null ; if [ $? -ne 0 ] ; then /usr/bin/ginstall -c -m 644 $file /home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu/docs/html ; fi done 2> /dev/null ; true
make[4]: Leaving directory /home/rshepard/GIS/GRASS/grass-6.5svn/gui/wxpython/docs'
make[3]: Leaving directory /home/rshepard/GIS/GRASS/grass-6.5svn/gui/wxpython/docs'
make /home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu/docs/html/wxGUI.PsMap.html
if [ "" != "" ] ; then GISRC=/home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu/demolocation/.grassrc65 GISBASE=/home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu PATH="/home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu/bin:$PATH" LD_LIBRARY_PATH="/home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu/bin:/home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu/lib:/usr/lib/qt/lib:/usr/lib/qt/lib:" LC_ALL=C --html-description < /dev/null | grep -v '</body>\|</html>' > wxGUI.PsMap.tmp.html ; true ; fi
../../../tools/mkhtml.sh wxGUI.PsMap ; mkdir -p /home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu/docs/html ; /usr/bin/ginstall -c -m 644 wxGUI.PsMap.tmp.html /home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu/docs/html/wxGUI.PsMap.html ; for file in *.png *.jpg ; do head -n 1 $file | grep '^#!' > /dev/null ; if [ $? -ne 0 ] ; then /usr/bin/ginstall -c -m 644 $file /home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu/docs/html ; fi done 2> /dev/null ; true
make /home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu/docs/html/wxGUI.Vector_Digitizer.html
if [ "" != "" ] ; then GISRC=/home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu/demolocation/.grassrc65 GISBASE=/home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu PATH="/home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu/bin:$PATH" LD_LIBRARY_PATH="/home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu/bin:/home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu/lib:/usr/lib/qt/lib:/usr/lib/qt/lib:" LC_ALL=C --html-description < /dev/null | grep -v '</body>\|</html>' > wxGUI.Vector_Digitizer.tmp.html ; true ; fi
../../../tools/mkhtml.sh wxGUI.Vector_Digitizer ; mkdir -p /home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu/docs/html ; /usr/bin/ginstall -c -m 644 wxGUI.Vector_Digitizer.tmp.html /home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu/docs/html/wxGUI.Vector_Digitizer.html ; for file in *.png *.jpg ; do head -n 1 $file | grep '^#!' > /dev/null ; if [ $? -ne 0 ] ; then /usr/bin/ginstall -c -m 644 $file /home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu/docs/html ; fi done 2> /dev/null ; true
make /home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu/docs/html/wxGUI.Components.html
if [ "" != "" ] ; then GISRC=/home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu/demolocation/.grassrc65 GISBASE=/home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu PATH="/home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu/bin:$PATH" LD_LIBRARY_PATH="/home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu/bin:/home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu/lib:/usr/lib/qt/lib:/usr/lib/qt/lib:" LC_ALL=C --html-description < /dev/null | grep -v '</body>\|</html>' > wxGUI.Components.tmp.html ; true ; fi
../../../tools/mkhtml.sh wxGUI.Components ; mkdir -p /home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu/docs/html ; /usr/bin/ginstall -c -m 644 wxGUI.Components.tmp.html /home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu/docs/html/wxGUI.Components.html ; for file in *.png *.jpg ; do head -n 1 $file | grep '^#!' > /dev/null ; if [ $? -ne 0 ] ; then /usr/bin/ginstall -c -m 644 $file /home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu/docs/html ; fi done 2> /dev/null ; true
make /home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu/docs/html/wxGUI.Modeler.html
if [ "" != "" ] ; then GISRC=/home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu/demolocation/.grassrc65 GISBASE=/home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu PATH="/home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu/bin:$PATH" LD_LIBRARY_PATH="/home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu/bin:/home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu/lib:/usr/lib/qt/lib:/usr/lib/qt/lib:" LC_ALL=C --html-description < /dev/null | grep -v '</body>\|</html>' > wxGUI.Modeler.tmp.html ; true ; fi
../../../tools/mkhtml.sh wxGUI.Modeler ; mkdir -p /home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu/docs/html ; /usr/bin/ginstall -c -m 644 wxGUI.Modeler.tmp.html /home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu/docs/html/wxGUI.Modeler.html ; for file in *.png *.jpg ; do head -n 1 $file | grep '^#!' > /dev/null ; if [ $? -ne 0 ] ; then /usr/bin/ginstall -c -m 644 $file /home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu/docs/html ; fi done 2> /dev/null ; true
make /home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu/docs/html/wxGUI.GCP_Manager.html
if [ "" != "" ] ; then GISRC=/home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu/demolocation/.grassrc65 GISBASE=/home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu PATH="/home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu/bin:$PATH" LD_LIBRARY_PATH="/home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu/bin:/home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu/lib:/usr/lib/qt/lib:/usr/lib/qt/lib:" LC_ALL=C --html-description < /dev/null | grep -v '</body>\|</html>' > wxGUI.GCP_Manager.tmp.html ; true ; fi
../../../tools/mkhtml.sh wxGUI.GCP_Manager ; mkdir -p /home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu/docs/html ; /usr/bin/ginstall -c -m 644 wxGUI.GCP_Manager.tmp.html /home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu/docs/html/wxGUI.GCP_Manager.html ; for file in *.png *.jpg ; do head -n 1 $file | grep '^#!' > /dev/null ; if [ $? -ne 0 ] ; then /usr/bin/ginstall -c -m 644 $file /home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu/docs/html ; fi done 2> /dev/null ; true
make /home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu/docs/html/wxGUI.Nviz.html
if [ "" != "" ] ; then GISRC=/home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu/demolocation/.grassrc65 GISBASE=/home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu PATH="/home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu/bin:$PATH" LD_LIBRARY_PATH="/home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu/bin:/home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu/lib:/usr/lib/qt/lib:/usr/lib/qt/lib:" LC_ALL=C --html-description < /dev/null | grep -v '</body>\|</html>' > wxGUI.Nviz.tmp.html ; true ; fi
../../../tools/mkhtml.sh wxGUI.Nviz ; mkdir -p /home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu/docs/html ; /usr/bin/ginstall -c -m 644 wxGUI.Nviz.tmp.html /home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu/docs/html/wxGUI.Nviz.html ; for file in *.png *.jpg ; do head -n 1 $file | grep '^#!' > /dev/null ; if [ $? -ne 0 ] ; then /usr/bin/ginstall -c -m 644 $file /home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu/docs/html ; fi done 2> /dev/null ; true
make /home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu/docs/html/wxGUI.Attribute_Table_Manager.html
if [ "" != "" ] ; then GISRC=/home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu/demolocation/.grassrc65 GISBASE=/home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu PATH="/home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu/bin:$PATH" LD_LIBRARY_PATH="/home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu/bin:/home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu/lib:/usr/lib/qt/lib:/usr/lib/qt/lib:" LC_ALL=C --html-description < /dev/null | grep -v '</body>\|</html>' > wxGUI.Attribute_Table_Manager.tmp.html ; true ; fi
../../../tools/mkhtml.sh wxGUI.Attribute_Table_Manager ; mkdir -p /home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu/docs/html ; /usr/bin/ginstall -c -m 644 wxGUI.Attribute_Table_Manager.tmp.html /home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu/docs/html/wxGUI.Attribute_Table_Manager.html ; for file in *.png *.jpg ; do head -n 1 $file | grep '^#!' > /dev/null ; if [ $? -ne 0 ] ; then /usr/bin/ginstall -c -m 644 $file /home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu/docs/html ; fi done 2> /dev/null ; true
/home/rshepard/GIS/GRASS/grass-6.5svn/gui/wxpython/docs' make[3]: Leaving
directory /home/rshepard/GIS/GRASS/grass-6.5svn/gui/wxpython/docs' make[2]:
make[1]: Leaving directory
Then, as root, I 'make install'. But, when I start GRASS I see:
[rshepard at salmo ~/GIS/GRASS/grass-6.5svn]$ grass65
Cleaning up temporary files ...
Starting GRASS ...
ERROR: wxGUI requires wxPython. libwx_gtk2u_xrc-3.0.so.0: cannot open shared
object file: No such file or directory
Error in GUI startup. If necessary, please
report this error to the GRASS developers.
Switching to text mode now.
Hit RETURN to continue...
Does this provide more detailed information that might lead one of you
developers to figure out where the problem is?
Thanks in advance,
Rich
Richard B. Shepard, Ph.D. | Have knowledge, will travel.
Applied Ecosystem Services, Inc. |
www.appl-ecosys.com Voice: 503-667-4517 Fax: 503-667-8863
