[GRASS-user] sample dataset for temporal data
Anna Petrášová kratochanna at gmail.com
Fri May 2 05:34:29 PDT 2014
One more thing, to test the dataset, look at the examples here:
http://courses.ncsu.edu/mea592/common/Assign_GISmdmodel/a_temporal.html
Anna
On Tue, Apr 29, 2014 at 5:07 PM, Anna Petrášová <kratochanna at gmail.com>wrote:
> Hi,
> since more and more users are using temporal framework, we should consider
> creating a sample dataset for temporal data. This could be used in the
> manual pages of t.* modules. Some of them still don't have any example and
> the existing examples are based on tests with generated data which is not
> the best way.
> Some time ago I created a climate dataset for North Carolina from publicly
> available data, it has monthly temperature average and monthly
> precipitation from 2000 to 2012. You can download it from here:
> http://courses.ncsu.edu/mea592/common/media/02/nc_climate_spm_2000_2012.zip
> There are no temporal vector data, just the standard precip. stations
> vector from nc_spm_08.
> So I suggest to use this, because it's consistent with nc_spm_08 but feel
> free to suggest something else.
> Best,
> Anna
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20140502/f06dcdf1/attachment-0001.html>
