[GRASS-user] help with r.hants
Veronica Andreo
veroandreo at gmail.com
Fri May 2 15:51:19 PDT 2014
Here's also the last part of the output when
g.gisenv set=DEBUG=3
r.hants ...
http://pastebin.com/cp139prq
Thanks!
Vero
2014-05-02 15:27 GMT-03:00 Veronica Andreo <veroandreo at gmail.com>:
> 2014-05-02 14:06 GMT-03:00 Markus Neteler <neteler at osgeo.org>:
> On Fri, May 2, 2014 at 6:20 PM, Veronica Andreo <veroandreo at gmail.com>
>> wrote:
>> > Hi Markus, all
>> > Thanks much for answering! and for the example!
>> >> > I'm using the following command to run r.hants on a series of 506
>> maps
>> >> > of
>> >> > chlorophyll. It seems to start thinking and a few seconds after i
>> get an
>> >> > error:
>> >> > r.hants file=lista_hants nf=6 fet=0.1 dod=5 delta=0.1 base_period=46
>> >> > ERROR: no temp files available
>> >> probably it runs out of memory? How many pixels does one map have?
>> > I have 506 maps, 146880 pixels each... maybe that's too much for my
>> laptop?
>> > :P
>> Please run your calculation in DEBUG mode:
>> g.gisenv set=DEBUG=1
>> r.hants ...
> done
> The relevant part for us is around this error message (it will print a
>> lot more of course).
>> You may dump the interesting part here
>> and send the resulting URL only.
> http://pastebin.com/ySYAwNJJ
>> We'll figure out! :)
> :) thanks much, again!
> Vero
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20140502/fb938de3/attachment.html>
