[GRASS-user] GRASS-7.0svn: Build Error ... Again
Thomas Adams
tea3rd at gmail.com
Sat May 3 10:06:06 PDT 2014
Hi Rich, Vaclav, others;
I don't know if this is at all helpful; but, I just upgraded to Ubuntu
14.04 and the upgrade was not completely flawlwss. However, in the process,
I tested my GRASS 6.4.3 and GRASS 7.0svn install, which both failed. I
ended up needed to rebuild and install gdal 1.9.2 and went to GRASS 7.0
(beta) which built and installed fine and works just fine.
I also had to reinstall the hdf5 libs as well to re-build gdal, using:
sudo apt-get install libhdf5-serial-dev
This is what I did afterwards:
sudo apt-get install \
build-essential \
make flex bison gcc libgcc1 g++ cmake ccache \
python python-dev python-qt4 python-qt4-dev \
python-opengl \
python-wxversion python-wxtools python-wxgtk2.8 \
python-dateutil libgsl0-dev python-numpy \
wx2.8-headers wx-common libwxgtk2.8-dev libwxgtk2.8-dbg \
libwxbase2.8-dev libwxbase2.8-dbg \
libncurses5-dev \
zlib1g-dev gettext \
libtiff4-dev \
tcl8.5-dev tk8.5-dev \
libcairo2 libcairo2-dev \
sqlite3 libsqlite3-dev \
libpq-dev \
libreadline6 libreadline6-dev libfreetype6-dev \
txt2tags \
libfftw3-3 libfftw3-dev \
libqt4-core libqt4-dbg libqt4-dev libqt4-gui libqt4-sql libqt4-qt3support \
lsb-qt4 qt4-designer qt4-dev-tools qt4-doc qt4-qtconfig \
libapt-pkg-perl resolvconf \
libjasper-dev \
ruby \
subversion \
libavcodec-dev \
libxmu-dev \
libavformat-dev libswscale-dev \
checkinstall \
libglu1-mesa-dev libxmu-dev
This had no effect, because I had all of this previously installed. My
GRASS 7.0 beta configure file looks like this:
./configure --with-opengl-includes=/usr/include/GL --enable-64bit
--with-cxx --with-readline --with-freetype=yes
--with-freetype-includes=/usr/include/freetype2/ --enable-largefile=yes
--with-opengl-libs=/usr/lib --with-geos=/usr/local/bin/geos-config
--with-tcltk-includes=/usr/local/include --with-tcltk-libs=/usr/local/lib
--with-sqlite --with-sqlite-includes=/usr/local/include
--with-sqlite-libs=/usr/local/lib --with-postgres
--with-postgres-includes=/usr/local/pgsql/include
--with-postgres-libs=/usr/local/pgsql/lib --with-python
--with-wxwidgets=/usr/bin/wx-config --with-proj-includes=/usr/local/include
--with-proj-libs=/usr/local/lib --with-proj-share=/usr/local/share/proj
--with-gdal=/usr/local/bin/gdal-config
--with-proj-includes=/usr/local/include --with-proj-libs=/usr/local/lib
Hope this is helpful...
Tom
On Sat, May 3, 2014 at 10:59 AM, Vaclav Petras <wenzeslaus at gmail.com> wrote:
> On Fri, May 2, 2014 at 1:48 PM, Rich Shepard <rshepard at appl-ecosys.com>wrote:
>> IOError: [Errno 2] No such file or directory:
>> '/home/rshepard/GIS/GRASS/grass-7.0svn/dist.i686-pc-
>> linux-gnu/gui/wxpython/xml/main_menu.xml'
>> make: *** [xml/menudata.xml] Error 1
> Can you please do
> ls
> /home/rshepard/GIS/GRASS/grass-7.0svn/dist.i686-pc-linux-gnu/gui/wxpython/xml/
> Missing main_menu.xml is a new problem. Again, it seems that something
> went wrong with the compilation. Perhaps the Makefile is wrong in this case.
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
Thomas E Adams, III
718 McBurney Drive
Lebanon, OH 45036
1 (513) 739-9512 (cell)
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20140503/a9b8750c/attachment.html>
