[GRASS-user] join r.coin-result to a vector attribute table
Helmut Kudrnovsky
hellik at web.de
Sat May 10 04:32:12 PDT 2014
Moritz Lennert wrote
> I would recommend using r.stats in=vr,rast2 to get a more easily
> reusable output. Then you can load the result into a table in your
> mapset database (db.in.ogr) and join it to your vector maps attribute
> table (v.db.join).
> Moritz
thanks for the hint, it was the way to go. used here:
http://alectoria.blogspot.co.at/2014/05/sun-terrain-open-data-and-open-source.html
before joining some kind of cross tab/pivot conversion of the r.stats-output
is needed.
thanks.
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/join-r-coin-result-to-a-vector-attribute-table-tp5138476p5139537.html
Sent from the Grass - Users mailing list archive at Nabble.com.
