[GRASS-user] GRASS-7svn: Build Errors
Rich Shepard
rshepard at appl-ecosys.com
Sat May 10 14:59:55 PDT 2014
I built and installed wxPython-3.0.0.0. Since previous attempts to build
7.1 threw errors in the gui/wxPython/ subdirectories I expected make to
complete error free. That did not happen with the latest update from the
subversion repository; build #60167. The error log is attached.
Do the configuration files differ between 6.x and 7.x? I'm using the same
configuration for both and 6.5svn builds without error.
Pointers appreciated,
Rich
GRASS GIS 7.1.svn 60167 compilation log
Started compilation: Sat May 10 14:29:57 PDT 2014
Errors in:
/home/rshepard/GIS/GRASS/grass-7.0svn/db/db.columns
/home/rshepard/GIS/GRASS/grass-7.0svn/db/db.connect
/home/rshepard/GIS/GRASS/grass-7.0svn/db/db.copy
/home/rshepard/GIS/GRASS/grass-7.0svn/db/db.createdb
/home/rshepard/GIS/GRASS/grass-7.0svn/db/db.databases
/home/rshepard/GIS/GRASS/grass-7.0svn/db/db.describe
/home/rshepard/GIS/GRASS/grass-7.0svn/db/db.drivers
/home/rshepard/GIS/GRASS/grass-7.0svn/db/db.dropdb
/home/rshepard/GIS/GRASS/grass-7.0svn/db/db.execute
/home/rshepard/GIS/GRASS/grass-7.0svn/db/db.login
/home/rshepard/GIS/GRASS/grass-7.0svn/db/db.select
/home/rshepard/GIS/GRASS/grass-7.0svn/db/db.tables
/home/rshepard/GIS/GRASS/grass-7.0svn/display/d.barscale
/home/rshepard/GIS/GRASS/grass-7.0svn/display/d.colorlist
/home/rshepard/GIS/GRASS/grass-7.0svn/display/d.colortable
/home/rshepard/GIS/GRASS/grass-7.0svn/display/d.erase
/home/rshepard/GIS/GRASS/grass-7.0svn/display/d.font
/home/rshepard/GIS/GRASS/grass-7.0svn/display/d.fontlist
/home/rshepard/GIS/GRASS/grass-7.0svn/display/d.geodesic
/home/rshepard/GIS/GRASS/grass-7.0svn/display/d.graph
/home/rshepard/GIS/GRASS/grass-7.0svn/display/d.grid
/home/rshepard/GIS/GRASS/grass-7.0svn/display/d.his
/home/rshepard/GIS/GRASS/grass-7.0svn/display/d.info
/home/rshepard/GIS/GRASS/grass-7.0svn/display/d.labels
/home/rshepard/GIS/GRASS/grass-7.0svn/display/d.linegraph
/home/rshepard/GIS/GRASS/grass-7.0svn/display/d.northarrow
/home/rshepard/GIS/GRASS/grass-7.0svn/display/d.profile
/home/rshepard/GIS/GRASS/grass-7.0svn/display/d.rast
/home/rshepard/GIS/GRASS/grass-7.0svn/display/d.rast.arrow
/home/rshepard/GIS/GRASS/grass-7.0svn/display/d.rast.num
/home/rshepard/GIS/GRASS/grass-7.0svn/display/d.rhumbline
/home/rshepard/GIS/GRASS/grass-7.0svn/display/d.text
/home/rshepard/GIS/GRASS/grass-7.0svn/display/d.title
/home/rshepard/GIS/GRASS/grass-7.0svn/display/d.vect
/home/rshepard/GIS/GRASS/grass-7.0svn/display/d.thematic.area
/home/rshepard/GIS/GRASS/grass-7.0svn/display/d.where
/home/rshepard/GIS/GRASS/grass-7.0svn/general/g.access
/home/rshepard/GIS/GRASS/grass-7.0svn/general/g.cairocomp
/home/rshepard/GIS/GRASS/grass-7.0svn/general/g.dirseps
/home/rshepard/GIS/GRASS/grass-7.0svn/general/g.filename
/home/rshepard/GIS/GRASS/grass-7.0svn/general/g.findetc
/home/rshepard/GIS/GRASS/grass-7.0svn/general/g.findfile
/home/rshepard/GIS/GRASS/grass-7.0svn/general/g.gisenv
/home/rshepard/GIS/GRASS/grass-7.0svn/general/g.gui
/home/rshepard/GIS/GRASS/grass-7.0svn/general/g.mapset
/home/rshepard/GIS/GRASS/grass-7.0svn/general/g.message
/home/rshepard/GIS/GRASS/grass-7.0svn/general/g.mkfontcap
/home/rshepard/GIS/GRASS/grass-7.0svn/general/g.mlist
/home/rshepard/GIS/GRASS/grass-7.0svn/general/g.mremove
/home/rshepard/GIS/GRASS/grass-7.0svn/general/g.pnmcomp
/home/rshepard/GIS/GRASS/grass-7.0svn/general/g.ppmtopng
/home/rshepard/GIS/GRASS/grass-7.0svn/general/g.region
/home/rshepard/GIS/GRASS/grass-7.0svn/general/g.tempfile
/home/rshepard/GIS/GRASS/grass-7.0svn/general/g.version
/home/rshepard/GIS/GRASS/grass-7.0svn/raster/r.basins.fill
/home/rshepard/GIS/GRASS/grass-7.0svn/raster/r.bitpattern
/home/rshepard/GIS/GRASS/grass-7.0svn/raster/r.buffer
/home/rshepard/GIS/GRASS/grass-7.0svn/raster/r.category
/home/rshepard/GIS/GRASS/grass-7.0svn/raster/r.circle
/home/rshepard/GIS/GRASS/grass-7.0svn/raster/r.clump
/home/rshepard/GIS/GRASS/grass-7.0svn/raster/r.coin
/home/rshepard/GIS/GRASS/grass-7.0svn/raster/r.colors
/home/rshepard/GIS/GRASS/grass-7.0svn/raster/r.colors.out
/home/rshepard/GIS/GRASS/grass-7.0svn/raster/r.composite
/home/rshepard/GIS/GRASS/grass-7.0svn/raster/r.compress
/home/rshepard/GIS/GRASS/grass-7.0svn/raster/r.cost
/home/rshepard/GIS/GRASS/grass-7.0svn/raster/r.covar
/home/rshepard/GIS/GRASS/grass-7.0svn/raster/r.cross
/home/rshepard/GIS/GRASS/grass-7.0svn/raster/r.describe
/home/rshepard/GIS/GRASS/grass-7.0svn/raster/r.distance
/home/rshepard/GIS/GRASS/grass-7.0svn/raster/r.drain
/home/rshepard/GIS/GRASS/grass-7.0svn/raster/r.external
/home/rshepard/GIS/GRASS/grass-7.0svn/raster/r.external.out
/home/rshepard/GIS/GRASS/grass-7.0svn/raster/r.fill.dir
/home/rshepard/GIS/GRASS/grass-7.0svn/raster/r.flow
/home/rshepard/GIS/GRASS/grass-7.0svn/raster/r.grow.distance
/home/rshepard/GIS/GRASS/grass-7.0svn/raster/r.gwflow
/home/rshepard/GIS/GRASS/grass-7.0svn/raster/r.his
/home/rshepard/GIS/GRASS/grass-7.0svn/raster/r.horizon
/home/rshepard/GIS/GRASS/grass-7.0svn/raster/r.in.arc
/home/rshepard/GIS/GRASS/grass-7.0svn/raster/r.in.ascii
/home/rshepard/GIS/GRASS/grass-7.0svn/raster/r.in.bin
/home/rshepard/GIS/GRASS/grass-7.0svn/raster/r.in.gdal
/home/rshepard/GIS/GRASS/grass-7.0svn/raster/r.in.gridatb
/home/rshepard/GIS/GRASS/grass-7.0svn/raster/r.in.mat
/home/rshepard/GIS/GRASS/grass-7.0svn/raster/r.in.png
/home/rshepard/GIS/GRASS/grass-7.0svn/raster/r.in.poly
/home/rshepard/GIS/GRASS/grass-7.0svn/raster/r.in.xyz
/home/rshepard/GIS/GRASS/grass-7.0svn/raster/r.info
/home/rshepard/GIS/GRASS/grass-7.0svn/raster/r.kappa
/home/rshepard/GIS/GRASS/grass-7.0svn/raster/r.latlong
/home/rshepard/GIS/GRASS/grass-7.0svn/raster/r.lake
/home/rshepard/GIS/GRASS/grass-7.0svn/raster/r.li/r.li.cwed
/home/rshepard/GIS/GRASS/grass-7.0svn/raster/r.li/r.li.dominance
/home/rshepard/GIS/GRASS/grass-7.0svn/raster/r.li/r.li.edgedensity
/home/rshepard/GIS/GRASS/grass-7.0svn/raster/r.li/r.li.mpa
/home/rshepard/GIS/GRASS/grass-7.0svn/raster/r.li/r.li.mps
/home/rshepard/GIS/GRASS/grass-7.0svn/raster/r.li/r.li.padcv
/home/rshepard/GIS/GRASS/grass-7.0svn/raster/r.li/r.li.padrange
/home/rshepard/GIS/GRASS/grass-7.0svn/raster/r.li/r.li.padsd
/home/rshepard/GIS/GRASS/grass-7.0svn/raster/r.li/r.li.patchdensity
/home/rshepard/GIS/GRASS/grass-7.0svn/raster/r.li/r.li.patchnum
/home/rshepard/GIS/GRASS/grass-7.0svn/raster/r.li/r.li.pielou
/home/rshepard/GIS/GRASS/grass-7.0svn/raster/r.li/r.li.renyi
/home/rshepard/GIS/GRASS/grass-7.0svn/raster/r.li/r.li.richness
/home/rshepard/GIS/GRASS/grass-7.0svn/raster/r.li/r.li.shannon
/home/rshepard/GIS/GRASS/grass-7.0svn/raster/r.li/r.li.shape
/home/rshepard/GIS/GRASS/grass-7.0svn/raster/r.li/r.li.simpson
/home/rshepard/GIS/GRASS/grass-7.0svn/raster/r.los
/home/rshepard/GIS/GRASS/grass-7.0svn/raster/r.mfilter
/home/rshepard/GIS/GRASS/grass-7.0svn/raster/r.mode
/home/rshepard/GIS/GRASS/grass-7.0svn/raster/r.neighbors
/home/rshepard/GIS/GRASS/grass-7.0svn/raster/r.null
/home/rshepard/GIS/GRASS/grass-7.0svn/raster/r.out.arc
/home/rshepard/GIS/GRASS/grass-7.0svn/raster/r.out.ascii
/home/rshepard/GIS/GRASS/grass-7.0svn/raster/r.out.bin
/home/rshepard/GIS/GRASS/grass-7.0svn/raster/r.out.gdal
/home/rshepard/GIS/GRASS/grass-7.0svn/raster/r.out.gridatb
/home/rshepard/GIS/GRASS/grass-7.0svn/raster/r.out.mat
/home/rshepard/GIS/GRASS/grass-7.0svn/raster/r.out.mpeg
/home/rshepard/GIS/GRASS/grass-7.0svn/raster/r.out.png
/home/rshepard/GIS/GRASS/grass-7.0svn/raster/r.out.pov
/home/rshepard/GIS/GRASS/grass-7.0svn/raster/r.out.ppm
/home/rshepard/GIS/GRASS/grass-7.0svn/raster/r.out.ppm3
/home/rshepard/GIS/GRASS/grass-7.0svn/raster/r.out.vrml
/home/rshepard/GIS/GRASS/grass-7.0svn/raster/r.out.vtk
/home/rshepard/GIS/GRASS/grass-7.0svn/raster/r.param.scale
/home/rshepard/GIS/GRASS/grass-7.0svn/raster/r.patch
/home/rshepard/GIS/GRASS/grass-7.0svn/raster/r.profile
/home/rshepard/GIS/GRASS/grass-7.0svn/raster/r.proj
/home/rshepard/GIS/GRASS/grass-7.0svn/raster/r.quant
/home/rshepard/GIS/GRASS/grass-7.0svn/raster/r.quantile
/home/rshepard/GIS/GRASS/grass-7.0svn/raster/r.random
/home/rshepard/GIS/GRASS/grass-7.0svn/raster/r.random.cells
/home/rshepard/GIS/GRASS/grass-7.0svn/raster/r.random.surface
/home/rshepard/GIS/GRASS/grass-7.0svn/raster/r.reclass
/home/rshepard/GIS/GRASS/grass-7.0svn/raster/r.recode
/home/rshepard/GIS/GRASS/grass-7.0svn/raster/r.region
/home/rshepard/GIS/GRASS/grass-7.0svn/raster/r.regression.line
/home/rshepard/GIS/GRASS/grass-7.0svn/raster/r.regression.multi
/home/rshepard/GIS/GRASS/grass-7.0svn/raster/r.report
/home/rshepard/GIS/GRASS/grass-7.0svn/raster/r.resamp.bspline
/home/rshepard/GIS/GRASS/grass-7.0svn/raster/r.resamp.filter
/home/rshepard/GIS/GRASS/grass-7.0svn/raster/r.resamp.interp
/home/rshepard/GIS/GRASS/grass-7.0svn/raster/r.resamp.rst
/home/rshepard/GIS/GRASS/grass-7.0svn/raster/r.resamp.stats
/home/rshepard/GIS/GRASS/grass-7.0svn/raster/r.resample
/home/rshepard/GIS/GRASS/grass-7.0svn/raster/r.rescale
/home/rshepard/GIS/GRASS/grass-7.0svn/raster/r.rescale.eq
/home/rshepard/GIS/GRASS/grass-7.0svn/raster/r.ros
/home/rshepard/GIS/GRASS/grass-7.0svn/raster/r.series
/home/rshepard/GIS/GRASS/grass-7.0svn/raster/r.series.accumulate
/home/rshepard/GIS/GRASS/grass-7.0svn/raster/r.series.interp
/home/rshepard/GIS/GRASS/grass-7.0svn/raster/r.shaded.relief
/home/rshepard/GIS/GRASS/grass-7.0svn/raster/r.slope.aspect
/home/rshepard/GIS/GRASS/grass-7.0svn/raster/r.solute.transport
/home/rshepard/GIS/GRASS/grass-7.0svn/raster/r.spread
/home/rshepard/GIS/GRASS/grass-7.0svn/raster/r.spreadpath
/home/rshepard/GIS/GRASS/grass-7.0svn/raster/r.statistics
/home/rshepard/GIS/GRASS/grass-7.0svn/raster/r.stats.zonal
/home/rshepard/GIS/GRASS/grass-7.0svn/raster/r.stats.quantile
/home/rshepard/GIS/GRASS/grass-7.0svn/raster/r.stream.extract
/home/rshepard/GIS/GRASS/grass-7.0svn/raster/r.stream.segment
/home/rshepard/GIS/GRASS/grass-7.0svn/raster/r.stream.slope
/home/rshepard/GIS/GRASS/grass-7.0svn/raster/r.sunhours
/home/rshepard/GIS/GRASS/grass-7.0svn/raster/r.support
/home/rshepard/GIS/GRASS/grass-7.0svn/raster/r.support.stats
/home/rshepard/GIS/GRASS/grass-7.0svn/raster/r.surf.area
/home/rshepard/GIS/GRASS/grass-7.0svn/raster/r.surf.contour
/home/rshepard/GIS/GRASS/grass-7.0svn/raster/r.surf.fractal
/home/rshepard/GIS/GRASS/grass-7.0svn/raster/r.surf.gauss
/home/rshepard/GIS/GRASS/grass-7.0svn/raster/r.surf.idw
/home/rshepard/GIS/GRASS/grass-7.0svn/raster/r.surf.idw2
/home/rshepard/GIS/GRASS/grass-7.0svn/raster/r.surf.random
/home/rshepard/GIS/GRASS/grass-7.0svn/raster/r.terraflow
/home/rshepard/GIS/GRASS/grass-7.0svn/raster/r.texture
/home/rshepard/GIS/GRASS/grass-7.0svn/raster/r.thin
/home/rshepard/GIS/GRASS/grass-7.0svn/raster/r.tile
/home/rshepard/GIS/GRASS/grass-7.0svn/raster/r.timestamp
/home/rshepard/GIS/GRASS/grass-7.0svn/raster/r.to.rast3
/home/rshepard/GIS/GRASS/grass-7.0svn/raster/r.to.rast3elev
/home/rshepard/GIS/GRASS/grass-7.0svn/raster/r.topidx
/home/rshepard/GIS/GRASS/grass-7.0svn/raster/r.topmodel
/home/rshepard/GIS/GRASS/grass-7.0svn/raster/r.transect
/home/rshepard/GIS/GRASS/grass-7.0svn/raster/r.univar
/home/rshepard/GIS/GRASS/grass-7.0svn/raster/r.uslek
/home/rshepard/GIS/GRASS/grass-7.0svn/raster/r.usler
/home/rshepard/GIS/GRASS/grass-7.0svn/raster/r.viewshed
/home/rshepard/GIS/GRASS/grass-7.0svn/raster/r.walk
/home/rshepard/GIS/GRASS/grass-7.0svn/raster/r.water.outlet
/home/rshepard/GIS/GRASS/grass-7.0svn/raster/r.watershed/front
/home/rshepard/GIS/GRASS/grass-7.0svn/raster/r.what
/home/rshepard/GIS/GRASS/grass-7.0svn/raster/r.what.color
/home/rshepard/GIS/GRASS/grass-7.0svn/raster/simwe/r.sim.water
/home/rshepard/GIS/GRASS/grass-7.0svn/raster/simwe/r.sim.sediment
/home/rshepard/GIS/GRASS/grass-7.0svn/raster3d/r3.cross.rast
/home/rshepard/GIS/GRASS/grass-7.0svn/raster3d/r3.gwflow
/home/rshepard/GIS/GRASS/grass-7.0svn/raster3d/r3.in.ascii
/home/rshepard/GIS/GRASS/grass-7.0svn/raster3d/r3.in.bin
/home/rshepard/GIS/GRASS/grass-7.0svn/raster3d/r3.in.v5d
/home/rshepard/GIS/GRASS/grass-7.0svn/raster3d/r3.info
/home/rshepard/GIS/GRASS/grass-7.0svn/raster3d/r3.mask
/home/rshepard/GIS/GRASS/grass-7.0svn/raster3d/r3.null
/home/rshepard/GIS/GRASS/grass-7.0svn/raster3d/r3.neighbors
/home/rshepard/GIS/GRASS/grass-7.0svn/raster3d/r3.out.ascii
/home/rshepard/GIS/GRASS/grass-7.0svn/raster3d/r3.out.bin
/home/rshepard/GIS/GRASS/grass-7.0svn/raster3d/r3.out.v5d
/home/rshepard/GIS/GRASS/grass-7.0svn/raster3d/r3.out.vtk
/home/rshepard/GIS/GRASS/grass-7.0svn/raster3d/r3.retile
/home/rshepard/GIS/GRASS/grass-7.0svn/raster3d/r3.support
/home/rshepard/GIS/GRASS/grass-7.0svn/raster3d/r3.timestamp
/home/rshepard/GIS/GRASS/grass-7.0svn/raster3d/r3.to.rast
/home/rshepard/GIS/GRASS/grass-7.0svn/vector/v.category
/home/rshepard/GIS/GRASS/grass-7.0svn/vector/v.colors.out
/home/rshepard/GIS/GRASS/grass-7.0svn/vector/v.convert
/home/rshepard/GIS/GRASS/grass-7.0svn/vector/v.generalize
/home/rshepard/GIS/GRASS/grass-7.0svn/vector/v.hull
/home/rshepard/GIS/GRASS/grass-7.0svn/vector/v.info
/home/rshepard/GIS/GRASS/grass-7.0svn/vector/v.in.dxf
/home/rshepard/GIS/GRASS/grass-7.0svn/vector/v.kcv
/home/rshepard/GIS/GRASS/grass-7.0svn/vector/v.lidar.correction
/home/rshepard/GIS/GRASS/grass-7.0svn/vector/v.lidar.edgedetection
/home/rshepard/GIS/GRASS/grass-7.0svn/vector/v.lidar.growing
/home/rshepard/GIS/GRASS/grass-7.0svn/vector/v.mkgrid
/home/rshepard/GIS/GRASS/grass-7.0svn/vector/v.net
/home/rshepard/GIS/GRASS/grass-7.0svn/vector/v.net.allpairs
/home/rshepard/GIS/GRASS/grass-7.0svn/vector/v.net.bridge
/home/rshepard/GIS/GRASS/grass-7.0svn/vector/v.net.centrality
/home/rshepard/GIS/GRASS/grass-7.0svn/vector/v.net.components
/home/rshepard/GIS/GRASS/grass-7.0svn/vector/v.net.connectivity
/home/rshepard/GIS/GRASS/grass-7.0svn/vector/v.net.distance
/home/rshepard/GIS/GRASS/grass-7.0svn/vector/v.net.flow
/home/rshepard/GIS/GRASS/grass-7.0svn/vector/v.net.spanningtree
/home/rshepard/GIS/GRASS/grass-7.0svn/vector/v.net.timetable
/home/rshepard/GIS/GRASS/grass-7.0svn/vector/v.net.visibility
/home/rshepard/GIS/GRASS/grass-7.0svn/vector/v.out.ascii
/home/rshepard/GIS/GRASS/grass-7.0svn/vector/v.out.postgis
/home/rshepard/GIS/GRASS/grass-7.0svn/vector/v.out.vtk
/home/rshepard/GIS/GRASS/grass-7.0svn/vector/v.outlier
/home/rshepard/GIS/GRASS/grass-7.0svn/vector/v.random
/home/rshepard/GIS/GRASS/grass-7.0svn/vector/v.support
/home/rshepard/GIS/GRASS/grass-7.0svn/vector/v.surf.bspline
/home/rshepard/GIS/GRASS/grass-7.0svn/vector/v.surf.idw
/home/rshepard/GIS/GRASS/grass-7.0svn/vector/v.timestamp
/home/rshepard/GIS/GRASS/grass-7.0svn/vector/v.to.3d
/home/rshepard/GIS/GRASS/grass-7.0svn/vector/v.to.rast
/home/rshepard/GIS/GRASS/grass-7.0svn/vector/v.what
/home/rshepard/GIS/GRASS/grass-7.0svn/vector/v.external.out
/home/rshepard/GIS/GRASS/grass-7.0svn/misc/m.measure
/home/rshepard/GIS/GRASS/grass-7.0svn/misc/m.nviz.image
/home/rshepard/GIS/GRASS/grass-7.0svn/misc/m.nviz.script
/home/rshepard/GIS/GRASS/grass-7.0svn/misc/m.transform
/home/rshepard/GIS/GRASS/grass-7.0svn/imagery/i.albedo
/home/rshepard/GIS/GRASS/grass-7.0svn/imagery/i.aster.toar
/home/rshepard/GIS/GRASS/grass-7.0svn/imagery/i.biomass
/home/rshepard/GIS/GRASS/grass-7.0svn/imagery/i.cca
/home/rshepard/GIS/GRASS/grass-7.0svn/imagery/i.cluster
/home/rshepard/GIS/GRASS/grass-7.0svn/imagery/i.eb.evapfr
/home/rshepard/GIS/GRASS/grass-7.0svn/imagery/i.eb.eta
/home/rshepard/GIS/GRASS/grass-7.0svn/imagery/i.eb.h_sebal01
/home/rshepard/GIS/GRASS/grass-7.0svn/imagery/i.eb.netrad
/home/rshepard/GIS/GRASS/grass-7.0svn/imagery/i.eb.soilheatflux
/home/rshepard/GIS/GRASS/grass-7.0svn/imagery/i.evapo.mh
/home/rshepard/GIS/GRASS/grass-7.0svn/imagery/i.evapo.pm
/home/rshepard/GIS/GRASS/grass-7.0svn/imagery/i.evapo.pt
/home/rshepard/GIS/GRASS/grass-7.0svn/imagery/i.evapo.time
/home/rshepard/GIS/GRASS/grass-7.0svn/imagery/i.emissivity
/home/rshepard/GIS/GRASS/grass-7.0svn/imagery/i.gensig
/home/rshepard/GIS/GRASS/grass-7.0svn/imagery/i.gensigset
/home/rshepard/GIS/GRASS/grass-7.0svn/imagery/i.group
/home/rshepard/GIS/GRASS/grass-7.0svn/imagery/i.his.rgb
/home/rshepard/GIS/GRASS/grass-7.0svn/imagery/i.landsat.toar
/home/rshepard/GIS/GRASS/grass-7.0svn/imagery/i.landsat.acca
/home/rshepard/GIS/GRASS/grass-7.0svn/imagery/i.maxlik
/home/rshepard/GIS/GRASS/grass-7.0svn/imagery/i.modis.qc
/home/rshepard/GIS/GRASS/grass-7.0svn/imagery/i.ortho.photo/i.ortho.camera
/home/rshepard/GIS/GRASS/grass-7.0svn/imagery/i.ortho.photo/i.ortho.elev
/home/rshepard/GIS/GRASS/grass-7.0svn/imagery/i.ortho.photo/i.ortho.rectify
/home/rshepard/GIS/GRASS/grass-7.0svn/imagery/i.rectify
/home/rshepard/GIS/GRASS/grass-7.0svn/imagery/i.rgb.his
/home/rshepard/GIS/GRASS/grass-7.0svn/imagery/i.segment
/home/rshepard/GIS/GRASS/grass-7.0svn/imagery/i.smap
/home/rshepard/GIS/GRASS/grass-7.0svn/imagery/i.target
/home/rshepard/GIS/GRASS/grass-7.0svn/imagery/i.topo.corr
/home/rshepard/GIS/GRASS/grass-7.0svn/imagery/i.pca
/home/rshepard/GIS/GRASS/grass-7.0svn/imagery/i.vi
/home/rshepard/GIS/GRASS/grass-7.0svn/imagery/i.fft
/home/rshepard/GIS/GRASS/grass-7.0svn/imagery/i.ifft
/home/rshepard/GIS/GRASS/grass-7.0svn/imagery/i.zc
/home/rshepard/GIS/GRASS/grass-7.0svn/ps/ps.map
/home/rshepard/GIS/GRASS/grass-7.0svn/scripts/d.rast.leg
/home/rshepard/GIS/GRASS/grass-7.0svn/scripts/g.extension
/home/rshepard/GIS/GRASS/grass-7.0svn/scripts/v.krige
/home/rshepard/GIS/GRASS/grass-7.0svn/temporal/t.connect
/home/rshepard/GIS/GRASS/grass-7.0svn/gui/wxpython/animation
/home/rshepard/GIS/GRASS/grass-7.0svn/gui/wxpython/mapswipe
/home/rshepard/GIS/GRASS/grass-7.0svn/gui/wxpython/gmodeler
/home/rshepard/GIS/GRASS/grass-7.0svn/gui/wxpython/rlisetup
/home/rshepard/GIS/GRASS/grass-7.0svn/gui/wxpython/psmap
/home/rshepard/GIS/GRASS/grass-7.0svn/gui/wxpython/dbmgr
/home/rshepard/GIS/GRASS/grass-7.0svn/gui/wxpython/vdigit
/home/rshepard/GIS/GRASS/grass-7.0svn/gui/wxpython/iclass
/home/rshepard/GIS/GRASS/grass-7.0svn/gui/wxpython/gcp
/home/rshepard/GIS/GRASS/grass-7.0svn/gui/wxpython/timeline
/home/rshepard/GIS/GRASS/grass-7.0svn/visualization/ximgview
/home/rshepard/GIS/GRASS/grass-7.0svn/visualization/wximgview
In case of errors please change into the directory with error and run 'make'.
If you get multiple errors, you need to deal with them in the order they
appear in the error log. If you get an error building a library, you will
also get errors from anything which uses the library.
Finished compilation: Sat May 10 14:32:48 PDT 2014
