[GRASS-user] Grass v.krige.py module issue
    Tahir Tamba
    tahir.tamba at gmail.com
    Mon May 19 12:46:27 PDT 2014
I installed vkrige.py using Grass Addons, and the installation goes
sucessfully. However when I click on the module to activate it via the menu
Raster-> Interpolate surfaces-> Ordinary kriging or block, I get the following
error message:
Unable to fetch interface description command 'v.krige.py'
See attached file to this email for the entire error message.
I use Grass 6.4.3 packaged with OSGeo4W version running on top of Windows 7.
Does this error message is a known bug on Windows. Is there a workaround?
Thanks
-------------- section suivante --------------
Une pi�ce jointe HTML a �t� nettoy�e...
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20140519/cefb07d6/attachment-0001.html>
Une pi�ce jointe autre que texte a �t� nettoy�e...
Nom: v.krige.py_error.png
Type: image/png
Taille: 34467 octets
Desc: non disponible
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20140519/cefb07d6/attachment-0001.png>
