[GRASS-user] execGRASS("r.diversity"): [Error 3] Cannot find path specified \\.grass7\\r.li
Glynn Clements
glynn at gclements.plus.com
Wed May 21 10:38:50 PDT 2014
[CC to grass-dev]
Sandra MacFadyen wrote:
> File "C:/Program Files (x86)/GRASS GIS 7.0.0beta2/scripts/r.diversity.py",
> line 116, in main
> os.mkdir(rlidir)
> WindowsError: [Error 3] The system cannot find the path specified:
> 'D:/Bands_processed1\\.grass7\\r.li'
r.diversity.py is broken on Windows:
home = os.path.expanduser('~')
rlidir = os.path.join(home, '.grass7', 'r.li')
The script tries to create an r.li subdirectory, but fails because the
parent directory doesn't exist.
$HOME/.grass7 is correct for Unix, but on Windows it's
%APPDATA%\GRASS7. From lib/init/grass.py:
# configuration directory
grass_env_file = None # see check_shell()
if sys.platform == 'win32':
grass_config_dirname = "GRASS7"
grass_config_dir = os.path.join(os.getenv('APPDATA'), grass_config_dirname)
else:
grass_config_dirname = ".grass7"
grass_config_dir = os.path.join(os.getenv('HOME'), grass_config_dirname)
