[GRASS-user] Stream distance - Elevation
Adrien ANDRÉ adrien.andre at onf.fr
Fri May 23 12:52:57 PDT 2014
Dear GRASS GIS community,
trying to compute the HAND model:
Nobre A. D., 2001 http://dx.doi.org/10.1016/j.jhydrol.2011.03.051
i'd like to get pixels from 0 to 2 meters higher than the stream pixel
they flow in (hoping i haven't missed any point in these papers).
I used
r.stream.distance difference=elevation_from_stream
with
r.mapcalc 'hand = elevation_from_stream < 2'
Comparing to a previous output computed using ArcGIS, differences appear.
Is it assumed that elevation difference is computed from the stream
pixel a pixel flows in (i.e following flow direction map)?
Or, is it in relation to the closest stream pixel ("as the crow flies"
distance)?
Would there be a difference providing the r.fill.dir output flow
direction map instead of the r.watershed one?
Many thanks in advance,
regards,
Adrien
Type: text/x-vcard
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20140523/7b9bea41/attachment.vcf>
