[GRASS-user] [GRASS-dev] execGRASS("r.diversity"): [Error 3] Cannot find path specified \\.grass7\\r.li
    Markus Neteler
    neteler at osgeo.org
    Fri May 23 23:51:06 PDT 2014
Hi Sandra,
On Thu, May 22, 2014 at 2:45 PM, Sandra MacFadyen <sandramf at live.co.za> wrote:
> Hi Luca,
> Thank you very much for your reply.
> With the north carolina dataset on image-band "lsat5_1987_10" I get the same error:
> (Thu May 22 14:35:33 2014)
> r.diversity input=lsat5_1987_10 at landsat prefix=lsat5_1987_div_ alpha=0.5 size=5
> ERROR: Illegal areas disposition
> Done.
> (Thu May 22 14:35:34 2014) Command finished (0 sec)
But did you set the computation region to the map "lsat5_1987_10"
*before*? Just to be sure...
Markus
