[GRASS-user] v.rast.stats by other column instead of 'cat'
Moritz Lennert mlennert at club.worldonline.be
Fri Nov 7 01:31:42 PST 2014
On 07/11/14 10:25, Javier Martínez-López wrote:
> Dear all,
> is it possible to use v.rast.stats or a similar function to compute
> univariate statistics from a raster map for each category present in a
> column of a vector map? As far as I know v.rast.stats only allow to do
> it by 'cat'.
I think this is true, but you can use v.reclass to create a vector map
according to your new categories and the run v.what.rast with that...
Moritz
