[GRASS-user] Problem with r.basin in grass7
Markus Neteler
neteler at osgeo.org
Tue Nov 11 11:55:46 PST 2014
Hi Andrea,
On Tue, Nov 11, 2014 at 3:30 AM, Andrea Timmermann <timmermann at gmx.at> wrote:
> Hi Markus,
> Thanks a lot for your answer.
> I downloaded the new r. basin and run
>> "r.basin map=map at Elevation prefix=o coordinates=-71.10394196,43.9865230801
>> threshold=19005 dir="C:\\Users\\Andrea\\Basins"
> and I get this error:
> ERROR: 'r.stream.distance' required. Please install 'r.stream.distance'
> first using 'g.extension r.stream.distance'
Update:
all the ugly error messages are gone as of r62708 and relevant fixes
earlier today. All this was a good test case to get the message
handling better.
Now you get:
GRASS 7.1.svn (nc_spm_08_grass7):~ > r.basin map=elevation
prefix=my_basin coord=637500.0,221750.0 dir=mydir threshold=1000
WARNING: 'r.stream.distance' required. Please install 'r.stream.distance'
ERROR: An ERROR occurred running r.basin
Concerning this issue:
> Then I run:
> and got:
> Downloading precompiled GRASS Addons <r.stream.distance>...
> Traceback (most recent call last):
> raise BadZipfile, "File is not a zip file"
> zipfile.BadZipfile: File is not a zip file
We have discovered an issue on the Windows build server which creates
the executables of the addon.
In essence, the r.stream.*.exe files are not generates daily as they
should. Martin will look into this asap.
Thanks for your patience! It leads to better code. And I am sure that
all this will be sorted out in the next days.
Best
Markus
