[GRASS-user] d.out.file / d.save - Shell-script use issues
Vaclav Petras
wenzeslaus at gmail.com
Wed Nov 12 06:35:32 PST 2014
I kindly ask command line users of d.* commands, especially those using d.*
commands in scripts, to test and participate in discussions concerning d.*
commands in GRASS GIS 7. For example, d.out.file was added (relatively)
lately to 7 and there is new command d.to.rast. They are designed to work
with wxGUI (including wx monitors).
Thanks,
Vaclav
[GRASS-dev] d.out.file
http://lists.osgeo.org/pipermail/grass-dev/2014-February/067362.html
[GRASS-user] d.out.file - Shell-script use ?
http://lists.osgeo.org/pipermail/grass-user/2014-November/071238.html
wxGUI d.mon and g.gui monitor command line support
http://trac.osgeo.org/grass/ticket/2233
Saves the contents of the active display monitor to a graphics file
http://grass.osgeo.org/grass70/manuals/d.out.file.html
Saves the contents of the active display monitor to a raster map
http://grass.osgeo.org/grass70/manuals/d.to.rast.html
On Wed, Nov 12, 2014 at 4:13 AM, Glynn Clements <glynn at gclements.plus.com>
wrote:
> César Augusto Ramírez Franco wrote:
> > As far as I understand, d.out.file only works with X monitors,
> This appears to be the case, although I have no idea why.
> The basic operation of d.out.file is to run "d.save" to extract the
> list of commands used to generate the display, then replay those
> commands on a PNG/PS/cairo monitor.
> The functionality on which d.save relies isn't specific to a
> particular driver.
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20141112/becd61a6/attachment.html>
