[GRASS-user] A question before I embark on a programming exercise
Rainer M Krug Rainer at krugs.de
Fri Nov 14 02:21:15 PST 2014
Glynn Clements <glynn at gclements.plus.com> writes:
> Moritz Lennert wrote:
>> r.mapcalc down_id = if(dir=1, id[1,1], if(dir=2, id[0,1], if(dir=3,
>> id[-1,1] .... etc
> r.mapcalc follows C expression syntax; "="is assignment, "==" is the
> equality test.
In this case shouldn't it be
| r.mapcalc down_id = if(dir==1, id[1,1], if(dir==2, id[0,1], if(dir==3, id[-1,1] .... etc
with "==" after the dir?
Rainer
Rainer M. Krug
email: Rainer<at>krugs<dot>de
PGP: 0x0F52F982
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20141114/b1be3185/attachment.pgp>
