[GRASS-user] Grass 6.4 and Opensuse 13.2
Tim Southern tim.southern at talktalk.net
Sat Nov 15 02:25:55 PST 2014
Dear All,
Grass 6.4 has completed a third automatic update this week!  However it still fails when trying to run the wxpython GU1
Following the last upgrade this morning attempting to run the Wxpthyon GUI returns
File”/opt/grass/etc/wxpython/wxgui.py”, line 34, in <module> from lmgr.frame import GMFrame
File “/opt/grass/etc/wxpython/lmgr/frame.py", line 46, in <module> from lmgr.layertree import LayerTree, UNIcons
File “/opt/grass/etc/wxpython/lmgr/layertree.py", line 37, in <module> from mapdisp.frame import MapFrame
File “opt/grass/etc/wxpython/mapdisp/frame.py”, line 52, in <module> from wxplot.profile import ProfileFrame
File “opt/grass/etc/wxpython/wxplot/profile.py”, line 23, in <module> import wx.lib.plot as plot
File ‘usr/lib/python2.7/site-packages/wx-2.8gtk2-unicode/wx/lib/plot.py” line 132 in <module> raise ImportError, “Numeric, numarray or numPy not found. \n. + msg
ImportError: Numeric, numarray or NumPy not found.
This module requires the Numeric/numarray or NumPy module, which could not be imported.  It probably is not installed(it’s not part of the standard Python distribution).  See the Numeric Python site (http://numpy.scipy.org <http://numpy.scipy.org/>) for information on downloading source or binaries.
Doing a Find on python returns the following
/etc/apparmour.d/abstractions/python
/usr/share/doc/packages/python
/usr/share/gdb/python
/usr/share/bash-completion/completion/python
/usr/share/kde4/apps/kconversion/scripting_support/python
/usr/lib/gimp/2.0/python
/usr/lib/libreoffice/share/scripts/python
usr/lib/python
/usr/bin/python
/opt/grass/etc/python
Doing a find on NumPy
/usr/lib/python2.7/site-packages/numpy
/usr/lib/python2.7/site-packages/numpy/core/include/numpy
Can anyone help get GRASS back up and running?
Thanks
Tim Southern
17, Park Close,
Sonning Common,
Oxfordshire
RG4 9RY
> On 14 Nov 2014, at 14:05, grass-user-request at lists.osgeo.org wrote:
> Send grass-user mailing list submissions to
> 	grass-user at lists.osgeo.org
> To subscribe or unsubscribe via the World Wide Web, visit
> 	http://lists.osgeo.org/mailman/listinfo/grass-user
> or, via email, send a message with subject or body 'help' to
> You can reach the person managing the list at
> 	grass-user-owner at lists.osgeo.org
> When replying, please edit your Subject line so it is more specific
> than "Re: Contents of grass-user digest..."
> Today's Topics:
>   1. FW:11/14/2014 2:34:02 AM 4 (Rebecca Stedham)
>   2. Re: Problem with r.basin in grass7 (Helmut Kudrnovsky)
>   3. Re: d.out.file / d.save - Shell-script use issues (Glynn Clements)
>   4. Re: A question before I embark on a	programming	exercise
>      (Glynn Clements)
>   5. Re: A question before I embark on a	programming	exercise
>      (Rainer M Krug)
>   6. Re: A question before I embark on a	programming	exercise
>      (Moritz Lennert)
>   7. Re: d.out.file / d.save - Shell-script use issues
>      (Nikos Alexandris)
>   8. Re: d.out.file / d.save - Shell-script use issues (Peter L?we)
>   9. Re: A question before I embark on a programming	exercise
>      (Thomas Adams)
> Message: 1
> Date: Thu, 14 Nov 2014 02:34:02 +0000
> From: "Rebecca Stedham" <rlstedham at btinternet.com>
> To: "hazel smith" <hazel.smith at aecom.com>, "gv1978"
> 	<gv1978 at gmail.com>,	"grass user request"
> 	<grass-user-request at lists.osgeo.org>,	"grass user"
> 	<grass-user at lists.osgeo.org>, "hr" <hr at redr.org.uk>,	"hcpickard"
> 	<hcpickard at gmail.com>,	"Hertha Taverner Wood" <herthat at gmail.com>
> Subject: [GRASS-user] FW:11/14/2014 2:34:02 AM 4
> Message-ID: <543442A5277F3033D1E770CCEE1F6E4D at xwn2.com>
> Content-Type: text/plain; charset="iso-8859-1"
> http://www.sansebastianradio.com/sqgruarc/rkemiqdhspxdpdqqqiphr.pvywnulkxerfsnggv
> Rebecca Stedham
> -------------- next part --------------
> An HTML attachment was scrubbed...
> URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20141114/5118f922/attachment-0001.html>
> Message: 2
> Date: Fri, 14 Nov 2014 01:02:26 -0800 (PST)
> From: Helmut Kudrnovsky <hellik at web.de>
> To: grass-user at lists.osgeo.org
> Subject: Re: [GRASS-user] Problem with r.basin in grass7
> Message-ID: <1415955746311-5172960.post at n6.nabble.com>
> Content-Type: text/plain; charset=us-ascii
> Andrea Timmermann wrote
>> and got:
>> Downloading precompiled GRASS Addons <r.stream.distance>...
>> Traceback (most recent call last):
>>   File "C:\Program Files (x86)\GRASS GIS
>> 7.1.svn/scripts/g.extension.py", line 1083, in <module>
>>     sys.exit(main())
>> 7.1.svn/scripts/g.extension.py", line 1071, in main
>>     install_extension(xmlurl)
>> 7.1.svn/scripts/g.extension.py", line 479, in
>> install_extension
>>     ret += install_extension_win(module)
>> 7.1.svn/scripts/g.extension.py", line 709, in
>>     zfobj = zipfile.ZipFile(fo)
>> 7.1.svn\Python27\lib\zipfile.py", line 766, in __init__
>>     self._RealGetContents()
>> 7.1.svn\Python27\lib\zipfile.py", line 807, in
>> _RealGetContents
>>     raise BadZipfile, "File is not a zip file"
>> zipfile.BadZipfile: File is not a zip file
> the r.stream.* addons are now back again for winGRASS, see e.g.
> http://wingrass.fsv.cvut.cz/grass71/addons/grass-7.1.svn/
> thanks to Martin.
> best regards
> Helmut
> View this message in context: http://osgeo-org.1560.x6.nabble.com/Problem-with-r-basin-in-grass7-tp5169155p5172960.html
> Sent from the Grass - Users mailing list archive at Nabble.com.
> Message: 3
> Date: Fri, 14 Nov 2014 09:31:37 +0000
> From: Glynn Clements <glynn at gclements.plus.com>
> To: Vaclav Petras <wenzeslaus at gmail.com>
> Cc: GRASS user list <grass-user at lists.osgeo.org>, Peter Löwe
> 	<peter.loewe at gmx.de>
> Subject: Re: [GRASS-user] d.out.file / d.save - Shell-script use
> 	issues
> Message-ID: <21605.52217.861520.833039 at cerise.gclements.plus.com>
> Vaclav Petras wrote:
>> I kindly ask command line users of d.* commands, especially those using d.*
>> commands in scripts, to test and participate in discussions concerning d.*
>> commands in GRASS GIS 7. For example, d.out.file was added (relatively)
>> lately to 7 and there is new command d.to.rast. They are designed to work
>> with wxGUI (including wx monitors).
> Could you choose a different prefix for these commands, and leave d.*
> for display commands?
> Message: 4
> Date: Fri, 14 Nov 2014 09:40:35 +0000
> To: Moritz Lennert <mlennert at club.worldonline.be>
> Cc: "grass-user at lists.osgeo.org" <grass-user at lists.osgeo.org>
> Subject: Re: [GRASS-user] A question before I embark on a	programming
> 	exercise
> Message-ID: <21605.52755.604436.245535 at cerise.gclements.plus.com>
> Moritz Lennert wrote:
>> r.mapcalc down_id = if(dir=1, id[1,1], if(dir=2, id[0,1], if(dir=3,
>> id[-1,1] .... etc
> r.mapcalc follows C expression syntax; "="is assignment, "==" is the
> equality test.
> Message: 5
> Date: Fri, 14 Nov 2014 11:21:15 +0100
> From: Rainer M Krug <Rainer at krugs.de>
> To: Glynn Clements <glynn at gclements.plus.com>
> 	exercise
> Message-ID: <m2ppcqulpg.fsf at krugs.de>
> Content-Type: text/plain; charset="us-ascii"
> Glynn Clements <glynn at gclements.plus.com> writes:
>>> id[-1,1] .... etc
>> equality test.
> In this case shouldn't it be
> | r.mapcalc down_id = if(dir==1, id[1,1], if(dir==2, id[0,1], if(dir==3, id[-1,1] .... etc
> with "==" after the dir?
> Rainer
> Rainer M. Krug
> email: Rainer<at>krugs<dot>de
> PGP: 0x0F52F982
> A non-text attachment was scrubbed...
> Type: application/pgp-signature
> Desc: not available
> URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20141114/b1be3185/attachment-0001.pgp>
> Message: 6
> Date: Fri, 14 Nov 2014 12:36:20 +0100
> From: Moritz Lennert <mlennert at club.worldonline.be>
> To: Rainer M Krug <Rainer at krugs.de>, Glynn Clements
> 	exercise
> Message-ID: <5465E934.4020605 at club.worldonline.be>
> Content-Type: text/plain; charset=windows-1252; format=flowed
>>>> id[-1,1] .... etc
>>> equality test.
> Yes, that's what Glynn is saying. Sorry, I wrote this example too quickly.
> Moritz
> Message: 7
> Date: Fri, 14 Nov 2014 14:07:08 +0200
> From: Nikos Alexandris <nik at nikosalexandris.net>
> Cc: GRASS user list <grass-user at lists.osgeo.org>, Peter L?we
> 	issues
> Message-ID: <20141114120708.GA11735 at tpx1c2g>
> * Vaclav Petras <wenzeslaus at gmail.com> [2014-11-12 09:35:32 -0500]:
> I quickly ran through most d.* commands (except for the d.vect* stuff).
> Some notes:
> d.erase:  I would like to do `d.erase black`. Black is a *good*
> background color.
> d.info -g:  Maybe change the -g's flag description? 's/geographic//' to
> avoid confusion(s) (geographic vs. projected, etc.)?
> d.rast.edit: let instructions/mouse actions explained inside a
> wx-monitor?
> For the d.what* commands, the icons to perform such queries exist
> already in a wx-Monitor, right?
> Isn't it possible to merge d.out.file and d.to.rast?  Maybe instruct
> "to.rast" with a flag or an explicit output name?
> Nikos
> Message: 8
> Date: Fri, 14 Nov 2014 13:45:59 +0100
> From: "Peter L?we" <peter.loewe at gmx.de>
> To: "Nikos Alexandris" <nik at nikosalexandris.net>
> 	issues
> Message-ID:
> 	<trinity-337e5b41-f6ee-4f8d-9991-3b7d0ec2781a-1415969159733 at 3capp-gmx-bs37>
> Content-Type: text/plain; charset=UTF-8
> Hi Nikos, dear all,
>> Nikos
> I strongly support this. The cumbersome re-import of the monitor content to use as a raster layer (d.to.file -> r.in.gdal -> r.composite) could be avoided.
> Peter
> Message: 9
> Date: Fri, 14 Nov 2014 07:05:41 -0700
> From: Thomas Adams <tea3rd at gmail.com>
> Cc: "grass-user at lists.osgeo.org" <grass-user at lists.osgeo.org>,	Glynn
> 	exercise
> Message-ID:
> 	<CAGxgkWhNqc_ho7yqagQ5etTp6Um2H9ZHxLH=qOy3W8Y4t7dmnA at mail.gmail.com>
> Content-Type: text/plain; charset="utf-8"
> Glynn & Rainer,
> YES, absolutely -- I caught that and made it '==' instead of '='. When
> typing quickly, I sometimes make that mistake and then have to correct
> myself. But fundamentally, Moritz' approach worked very well and produced
> what I needed. I have a more difficult problem now, something I think I can
> only resolve by using higher resolution data. But, that is OK, too, because
> I should get better modeling results in the end. I'm trying to create my
> own approach to generating the file, that when used by the model, gives
> essentially the same results.
> The folks who wrote the model and software to generate this runoff/flow
> connectivity file between pixels, found that with coarser pixel
> resolutions, the connection between pixels was badly distorted, in
> physically unreasonable ways. I don't have their original code, so I can
> not use it, plus, I really want to model at much finer spatial resolutions
> anyway, where the problem should go vanish.
> So, I just need to use higher resolution DEM data, which I have, rather
> than trying to do things at the default 4km resolution.
> One question I have: it would be very nice to be able to show how the
> pixels are connected using vectors, essentially the drainage network. Any
> thoughts how to do this?
> Regards,
> Tom
>>>> id[-1,1] .... etc
>>> equality test.
>> id[-1,1] .... etc
>> Rainer
>> Rainer M. Krug
>> PGP: 0x0F52F982
> URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20141114/ab2e2770/attachment.html>
> End of grass-user Digest, Vol 103, Issue 23
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20141115/79faf383/attachment-0001.html>
