[GRASS-user] Problem with r.basin in grass7
    Helmut Kudrnovsky
    hellik at web.de
    Sun Nov 16 04:22:24 PST 2014
Andrea Timmermann wrote
> Hi !!
> Thanks for the update.
> I reinstalled the latest grass  (version 13.11) and could also
> install all the r.stream addons without problems.
> There is still a problem with r.basin, however.
> When I run:
> "r.basin map=map at Elevation prefix=o
> coordinates=-71.10394196,43.9865230801 threshold=19005
> dir=C:\\Users\\Andrea\\Basins"
> I get:
> Width Function | quantiles
> 9291 | 0.05
> 15726 | 0.15
> 27145 | 0.3
> 31933 | 0.4
> 35026 | 0.5
> 38212 | 0.6
> 41192 | 0.7
> 49125 | 0.85
> 56807 | 0.95
> Done!
> All in RAM calculation - method <DOWNSTREAM>...
> Reading raster map <o_map_stream_e>...
> Reading raster map <o_map_drainage>...
> Finding nodes...
> Reading raster map <r_elevation_crop>...
> Calculate downstream parameters...
> Writing raster map <o_map_hillslope_distance>...
> First pass
> Writing output map
> r.stats.zonal done
> r.info done
> r.mapcalc done
> ERROR: Reading raster map <o_map_basin@> request for row -130 is
> outside region
> An ERROR occurred running r.basin
> Please check for error messages above or try with another pairs of outlet
> coordinates"
tested r.basin here on my side:
r.basin --verbose map=dem_linked at PERMANENT prefix=a
coordinates=-51121.42352,193901.704819 dir=C:\tmp\rstreamtest
threshold=12000
(Sun Nov 16 13:12:48 2014) Befehl ausgeführt (40 Min 25 Sek)
r.basin finishes here.
please try to reset and align your region to the DEM before a r.basin-run.
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/Problem-with-r-basin-in-grass7-tp5169155p5173189.html
Sent from the Grass - Users mailing list archive at Nabble.com.
