[GRASS-user] Problem with r.basin in grass7
Margherita Di Leo
diregola at gmail.com
Tue Nov 18 00:38:35 PST 2014
Hi Andrea,
On Tue, Nov 18, 2014 at 3:55 AM, Andrea Timmermann <timmermann at gmx.at>
wrote:
> Hi Helmut,
> Thanks for your email.
> I set again the area and resolution with g.region before running r.basin.
> I also deleted all files except my DEM.
> Now I get a different error ...
> When I run
> "*r.basin map=map at Elevation prefix=o
> coordinates=-71.10394196,43.9865230801 threshold=19005
> dir=C:\\Users\\Andrea\\Basins*"
> I get:
> *Building topology for vector map <o_map_ord_1 at Elevation>... Registering
> primitives... 10 primitives registered 558 vertices registered Building
> areas... 0 areas built 0 isles built Attaching islands... Attaching
> centroids... Number of nodes: 20 Number of primitives: 10 Number of points:
> 0 Number of lines: 10 Number of boundaries: 0 Number of centroids: 0 Number
> of areas: 0 Number of isles: 0 Updating attributes... r.to.vect complete.
> All in RAM calculation... ERROR: Region resolution and raster map
> <o_map_strahler> resolution differs. Run 'g.region rast=o_map_strahler' to
> set proper region resolution*"
> I run *g.region rast=o_map_strahler, *but then I have to delete all files
> and start over again running r.basin.
Yes if you change the region you have to delete the files created in the
previous run (if they have same name) or allow overwrite.
Best regards,
Dr. Margherita DI LEO
Scientific / technical project officer
European Commission - DG JRC
Institute for Environment and Sustainability (IES)
Via Fermi, 2749
I-21027 Ispra (VA) - Italy - TP 261
Tel. +39 0332 78 3600
margherita.di-leo at jrc.ec.europa.eu
Disclaimer: The views expressed are purely those of the writer and may not
in any circumstance be regarded as stating an official position of the
European Commission.
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20141118/8bde501b/attachment.html>
